03-14-2010, 10:45 AM | #1 |
looking for advice.
OK have the frame going to start a k5 2wd and going to put in a trailing arm rear suspension with bags don't mind cutting the floor but want to keep some kind of rear seat. Now, with that said how would that work with a dropmember in front. would that be to low in front compared to the rear.
some advice please, Falze |
03-15-2010, 01:48 PM | #2 |
Low & Fast!
Re: looking for advice.
It will have a rake to it. but if you are going with a hot rod look it will look sweet. Mine sits up in the back and here is one that Ken did. His is stock floor with a small C.
03-24-2010, 08:46 AM | #3 |
How much difference would it be for the dropmember setup or just go with tublar a arm set up with bags on both. Would lime the a arm set anyway. Hey Travis your blazer is top notch in my book!!!!! Have had quite a few just can't get the one to keep.
Thanks Mark |
03-24-2010, 10:26 AM | #4 |
the a-arms are not going to make a diff as far as how low it can go...here is mine, it is a burb but you get the idea, mine is with stock arms and uncut cups from SD, and a 1 5/8 chopped crossmember. And is all under the stock floor in the back.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
03-24-2010, 07:30 PM | #5 |
Is it better to go with the dropmember to achieve more ground clearance and to run the rack and pinion. Then just stay with the stock a arms untill later in my build??
Thanks Mark |
03-26-2010, 12:49 AM | #6 |
I believe this is the best way to go. The dropmember takes care of a lot of problems laying out a c10: deletes the steering box, centers the wheels in the wheel wells, and essentially bodydrops the front to name a few. Plus the newest version (v3.2) is tubular and looks wicked as hell, and Nate is a top notch dude, he texted me my tracking number at 9:30pm on a sunday night.
http://i92.photobucket.com/albums/l3...burban-1-1.jpg |
04-04-2010, 10:54 AM | #7 |
thanks for the advice. I think i will stick to the dropmember up front. Just want to say also that this site has so much help and info on it glad I found it. Trying to find a few pics of my old blazer and will post.
Thanks Mark |
04-04-2010, 07:22 PM | #8 |
I'll be watching this one. I have been think about doing the same thing with my 2wd. I want to do it more for handling than drop. Plus I don't lose my back seat.
06' GMC 1500 Crew cab..... |
