03-14-2010, 01:04 PM | #1 |
Drop Coil Springs
I am looking for a front 3" drop lowering spring and did not know which was the best brand to buy. I have heard bad things about several companies and was hoping I could get some input. Thanks
03-14-2010, 02:06 PM | #2 |
Senior Enthusiast
Re: Drop Coil Springs
I bought 1" lowering springs from Chisholm Suspension about 10 years ago, and one of them sagged another inch within a year. I would not recommend them, but it appears they've gone out of business anyway. Hopefully another member can provide a positive recommendation.
03-14-2010, 05:14 PM | #3 |
Rollin' Old Skool
i ran Western Chassis dropped spindles & springs on my old 93 fullsize Chevy, & they were nice...my 88 S-10 blazer had 3" drop coils too, but i'm not sure what brand...i know DJM & Belltech are other companies you could check with
03-14-2010, 11:42 PM | #4 |
question? i decided to crank the tosions loose to lower the front end, would it effect it
at all if i wanna go with a 2" lowered coil as well? or just go with the torsion lowering? Last edited by 62fresh; 03-14-2010 at 11:44 PM. |
03-15-2010, 01:06 AM | #5 |
60-66 Nut
I assume you're talking about the rear coil spring? If so then that won't really have any effect on the front. That will just drop the rear. It all depends on what stance you want.
03-15-2010, 02:09 AM | #6 | |
shock in the front effect the ride quality at all? Last edited by 62fresh; 03-15-2010 at 02:22 AM. |
03-15-2010, 06:26 AM | #7 |
"Where were you in '62?"
torsion bar lowering
http://67-72chevytrucks.com/vboard/s...d.php?t=325329 2" Front Lowering Springs for '60-'72 Chevy 1/2 ton truck http://67-72chevytrucks.com/vboard/s...d.php?t=328003 Early Classic's http://www.earlyclassic.com/home.aspx 1960-62 Front Suspension Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=366828 Classic Performance Products http://www.classicperform.com/6092chevtrk.htm 1960 Torsion bar removal http://67-72chevytrucks.com/vboard/s...d.php?t=302899
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-15-2010, 09:15 PM | #8 |
Has anyone used CPP lowering springs? If so, how do they hold up?
03-15-2010, 10:15 PM | #9 |
1Bad62Pro/Street thats the info i needed thanks bro
