03-14-2010, 01:32 PM | #1 |
New Member
Barn Door Conversion Question????
Guys,
I'm converting from hatch and tailgate to barn doors on my 72 burb and it looks like there is no access to get any nuts and washers in to bolt down the upper door strike, rubber bumpers, and door sliders/checks. What have you guys done? Sheet metal screws? Do you think the screws are going to hold everything tight? Thanks, Kevin |
03-14-2010, 01:39 PM | #2 |
New Member
Re: Barn Door Conversion Question????
..............What you you think about rivet nuts?
03-14-2010, 01:47 PM | #3 |
That's what I would do. You might want to do a test hole and see if the required plate is already there. You might get by with just drilling and tapping the correct size of hole....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-14-2010, 01:52 PM | #4 |
One of the mounting holes was already there on mine...
03-14-2010, 07:28 PM | #5 |
member
Perhaps you could collect a couple more of the round plastic plugs that are common in the rear gate. Drill the holes for the strikeplate. Then drill a hole on the inside over each strikeplate location hole and slip the nuts in through the hole and tighten them up. Then put the plugs in the hole. I cut a slot in the strikeplate location and then filled the holes.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 03-14-2010 at 07:29 PM. |
03-14-2010, 08:52 PM | #6 |
Does this picture help find the location you need. This is a 70.
