Old 02-04-2003, 01:08 AM   #1
case_bt
case_bt's Avatar
Truck pics after Disc brake convert,new grill and wheels
before
case_bt is offline   Reply With Quote
Old 02-04-2003, 01:09 AM   #2
case_bt
case_bt's Avatar
no grill just after disc brake convert
Old 02-04-2003, 01:10 AM   #3
case_bt
case_bt's Avatar
new grill after installed yesterday
Old 02-04-2003, 01:10 AM   #4
case_bt
case_bt's Avatar
side tonite
Old 02-04-2003, 01:12 AM   #5
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Thumbs up
Where did you buy your grille??
Sure looks great, clean truck.
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 02-04-2003, 01:12 AM   #6
case_bt
case_bt's Avatar
pass side morning
Old 02-04-2003, 01:14 AM   #7
case_bt
case_bt's Avatar
bought grill from GMC PAUL
Old 02-04-2003, 01:16 AM   #8
DanoDMano
DanoDMano's Avatar
Did you strip the truck of the moulding, or did you buy it that way??
I stripped mine too, but sometimes wish I would have left the bottom on!!!
Power Locks,
Truck Photos
Old 02-04-2003, 01:16 AM   #9
Shane
Shane's Avatar
looking good
Shane is offline   Reply With Quote
Old 02-04-2003, 01:18 AM   #10
67cst
i love summertime
67cst's Avatar
what kinda fender is that? did it fit as good as the original?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-04-2003, 01:19 AM   #11
case_bt
case_bt's Avatar
bought the truck with molding gone I want to lower it and go with bigger wheels but next step is body work and rust repair
Old 02-04-2003, 01:21 AM   #12
case_bt
case_bt's Avatar
the fender came from GMC Pauls it fits great I think I need to shim the bottom up a little behind the wheel well I'll do that when I get my new inner fenders
Old 02-04-2003, 01:24 AM   #13
DanoDMano
DanoDMano's Avatar
Case_bt
Here is my '70 with a 2" drop.
I also want to lower it another 3" with some drop spindles!!
Power Locks,
Truck Photos
Old 02-04-2003, 07:27 AM   #14
GMCPaul
Thumbs up
Looking Good case_bt!!! I can't wait to see the finished truck when your done with all mods!!!
GMCPaul
GMCPaul is offline   Reply With Quote
Old 02-04-2003, 01:49 PM   #15
70c10
67-72 Addict!
70c10's Avatar
Both you guys have sweet trucks!, case bt what is the name of that color?. I'm trying to talk my dad into painting his that color.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-04-2003, 02:12 PM   #16
case_bt
case_bt's Avatar
It the teal green
Chevy used in the early 90's on the fullsize and Geo Trackers
Old 02-04-2003, 02:26 PM   #17
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Sweet truck! Keep us updated!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 02-04-2003, 04:13 PM   #18
72MARIO
72MARIO's Avatar
case-bt
Who makes that fender does it has CY stamped in it anywhere? Because I bought two 67 fenders and they dont fit very nice. Later Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-04-2003, 06:40 PM   #19
treefrog
Truck Pic
I've got that one saved to disk. Very nice truck. TF
treefrog is offline   Reply With Quote
Old 02-04-2003, 08:40 PM   #20
case_bt
case_bt's Avatar
72Mario
I bought the fender from GMCPAUL IT fits great I just need to shim the fender up at the bottom behind the fender well probably correct with just one washer
Old 02-04-2003, 09:11 PM   #21
68gmcjon
Got earplugs?
68gmcjon's Avatar
Where did you get your disc brake convert done?
1968 GMC
Original A/C, bucket seats, PS,PB
396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression
Alltogether 411HP and 446ft/lbs
Dana 60 w/ 3.54 gears
Turbo 400 tranny
Why would you have anything other than a big block? HAHA
68gmcjon is offline   Reply With Quote
Old 02-04-2003, 11:13 PM   #22
case_bt
case_bt's Avatar
I did the conversion myself using 71 parts
spindles
rotors
calipers
outer tierod
rubber hoses
70 model outer tierod for new inner tierod
CPP tierod adjuster conversion part.
I have one extra set part # cp4sc
http://www.classicperform.com/6092chevtrk.htm
