Old 03-14-2010, 05:53 PM   #1
BigRed76
BigRed76's Avatar
Dome Light Wiring
I've got a 76 K10 stepside, and my problem at hand is that the dome light does not work. I traced down the wires and the white ground wires are all connected and good, but the orange wire is disconnected and just laying on the floor next to the fuse box. At the end of the orange wire it splices off into a 2nd wire that is only about 3 inches long, and both of them have plastic connectors on them. Does anyone know where these wires are supposed to be connected to?
And by the way, the truck does have the underdash courtesy light, and it works. Any ideas or input would be greatly appreciated.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 03-14-2010, 08:14 PM   #2
electrician42
electrician42's Avatar
Re: Dome Light Wiring
the orange wire should tie into the orange wiring going to your courtsey light.. the white wires go the switches that are grounded on other side of the contacts ..id look closer around fuse box area you should find the connections somewhere ...hope this helps some ...
electrician42 is offline   Reply With Quote
Old 03-15-2010, 02:33 AM   #3
Stepsideride
Ok...the orange wire is what gets a constant 12 volt...you should have a total of three orange wires.....one running to rear dome.....one running to headlght switch and one heading to the floorboard courtesy lamp...the white wires run from the door switches and feed into the courtesy lamp, dome lamp and head light switch as well.....this way it allows two circuits to work...Doors open and Dashlight Dimmer turned all the way left.
Stepsideride is offline   Reply With Quote
Old 03-19-2010, 06:38 PM   #4
BigRed76
BigRed76's Avatar
Wink Re: Dome Light Wiring
Alright, I will trace down the wires from the underdash light and see where they go. Thanks for the help!
Zach
Old 03-20-2010, 11:32 AM   #5
thrtsxchambers
thrtsxchambers's Avatar
is there a orange wire under you driver side carpet that runs behind the seat and up the back pillar? If so connect it to the orange wire that is coming off the fuse box and it should work. You said the floor light works, what wire is running to it , it should be orange.
thrtsxchambers is offline   Reply With Quote
Old 03-20-2010, 09:04 PM   #6
BigRed76
BigRed76's Avatar
well the orange wire from the underdash light runs to the headlight switch, so i connected the orange wire from the dome light to that same wire at the headlight switch and problem solved. It works great, so thanks for all the help guys. I appreciate it.
Zach
Old 03-20-2010, 10:18 PM   #7
RuralRoute C-30
RuralRoute C-30's Avatar
Explains a lot to me now that orange wire is brought up. Found the floor courtesy light under the ashtray and what was left of the orange wire from a previous owner's mouse problem.
That courtesy light wiring was literally gone but for a few strands of orange. I did tape it off to isolate it for now. Didn't relate the two but it makes sense. Explains why the dome light needs attention next!
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
