Old 03-14-2010, 06:56 PM   #1
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Stock wheels/radial tires
Can i use my stock 16 inch wheels that have tube's in them and install new tubless radial tires on them for my 62 gmc ? I want to make my own www's and paint my stock wheels and install my factory hubcaps, my concern is will they hold air, i drive my truck maybe 20 miles a year, thanks, matt
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 03-15-2010, 02:17 AM   #2
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Re: Stock wheels/radial tires
Yes you can. Your wheels shouldn't leak unless there is something wrong with them. Some tires just require to be run with tubes.
kalirodding is offline   Reply With Quote
Old 03-15-2010, 05:06 AM   #3
blackedoutharley
If your stock wheels are split rims you must run tubes.. just make sure that you are running a tube rated for radial tires... Yes, there is a difference.
blackedoutharley is offline   Reply With Quote
Old 03-15-2010, 06:38 AM   #4
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
no there not split rims i mount em and try them out thanks
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 03-15-2010, 03:30 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
The main reason for running tubes on the original rims isn't so much to make sure the tires will hold air, it's because the original rims didn't have safety beads formed into the rims. Safety bead rims were pioneered by Chrysler in the mid 50's, but didn't become standard equipment with the other manufacturers for another decade or more. In the days before enlightenment GM and Ford provided tubeless tires on non-safety bead wheels as standard equipment for years. Now it's a liability issue, like the tread belt/tire failures with Firestone a few years back. The benefit of the safety bead was the tire wouldn't separate from the rim if it went flat, or peel off the rim in a hard turn with an under inflated tire. For us do-it-yourselfers the advent of the safety bead was a pita, making it much more difficult to mount and dismount tires with hand tools.
Even the older 50's-60's rims that were held together with rivets will not leak with tubeless tires, unless something is rusty or defective. With all that said, it is a good idea to run radial tubes in radial tires on these old rims as extra insurance keeping everything together in case of an under inflated tire or a flat.
