Old 03-14-2010, 07:35 PM   #1
rennalds
truck consistantly dies
I have a 71 chevy and any time i take my foot off of the gas the truck dies.
otherwords it will not idle..
what are some possible problems i can check for??
rennalds is offline   Reply With Quote
Old 03-14-2010, 07:43 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: truck consistantly dies
6 or 8?
Vaccum leak, possible fuel problems. Hard to tell with out seeing it. But if it runs with the foot on the gas strong, Id start with those two, wouldnt hurt to see what the fuel pump volume is producing.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-14-2010, 08:01 PM   #3
jay6891
Car Knocker
jay6891's Avatar
In gear or neutral? Auto or stick?
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 03-14-2010, 08:08 PM   #4
chevroletman223
Dan
chevroletman223's Avatar
first thing i would check if you havent already is fuel mixture on the carb, and the idle set screw, could be idle is set too low. hope this helps. Dan
1968 C10 Short Fleet - L79 327, th350
1971 Nova - 327, Th350, 3.73 posi
1971 K10 Short fleet - 350/350
1971 K20 longbox - 350, 4spd
1970 Chevelle, Tunnel ram set up 355, th350
1986 C30 Dually, 454/400
1967 Impala 4 door hardtop, Supernatural clone
1968 Camaro, 327, pwerglide
1967 camaro, numbers match 350, powerglide, bench seat car
1968 Nova, Numbers match 6cyl, powerglide
1968 Nova, 327, th350
1970 Impala, 350, Th350
1968 Impala, Numbers match 350, Th350
1971 Chevelle SS, Numbers match 350, muncie
chevroletman223 is offline   Reply With Quote
Old 03-14-2010, 09:33 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Also check your timing, if it's too retarded it'll do this as well.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-14-2010, 11:13 PM   #6
rennalds
Its a v-8 automatic and it dies in park and also in drive il have to check neutral tomorrow ..the more u drive it it seems to die more..
Old 03-15-2010, 06:44 AM   #7
cdowns
cdowns's Avatar
a complete tune up is a great place to start// points plugs plug wires filters all need routine maintenence as well as checking for cracked dryrotted vaccume hoses cleaning up electrical connections is good too
a good service manual will show you how to perform these tasks properly//plus it will show you how to get to the fuel filter inside the carb
