15 inch wheel on 3/4 ton axles
i know its possible i have seen it but what do i need to do to make it work hub grinding? anybody?
![]() Join Date: Sep 2004
Re: 15 inch wheel on 3/4 ton axles
This is for Dana 60, but it might give you somewhat of an idea.
http://coloradok5.com/d60calipergrind.shtml
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) Last edited by Meatman; 03-14-2010 at 11:13 PM. |
You gave to grind a little bit off of the calipers, mainly the casting flash. I used this oppertunity to make my calipers completely smooth, but that was just for a custom look. If you still have drum brahes on the back then you won't have to do anything to them.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
