Serpentine belt system
Hey guys, so I'm going to change over to a serpentine belt system because I'm tired of messing with these belts. My question is what year model car/truck do I look for? I have a 383 (standard 350 block) but it has a 85 year model 1 peace rear main 400 crank.
I know someone has to have done this swap, what all do I need to look out for? Thanks Bryan
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
![]() Join Date: Sep 2004
Re: Serpentine belt system
Probably looking at like 88 or 89 to like 98? Dont know off top of my head for sure. You can also get the same setup of a 3rd camaro or firebird. I know for a fact that it would be 88-92 if you looked on those.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
you said you have a stroker motor. does your heads still have all the acc. holes?
http://www.gulftruckinc.com |
BAD BOW-Silverado XST
Squarebody Aficionado
you can use a serp kits from almost any motor, even the 4.3 s10s and astros.
#6 | |
Hey G, my son will be going to his Moms Wed. Maybe we'll meet up one day this week so I can get a closer look at your system.
I guess one of the things that worry me is the crank pulley. I know the flywheel for a 400 is different then a 350. But I can't remember if the pulley is. I thought it was. That's why I was wondering which one to use.
the only thing that i beleive is different is the balancer, but when you change the serp kit you have to change the crank pulley and all the pulleys in that case, and you will have to change your waterpump too.
There is a V6 and V8 pulley. I had to change my 4.3 setup to a V8 crank pulley. Everthing else bolted up. Check your heads. If each head has three holes in it, your can bolt on the brackets. All the other holes are on the block.
I'm pretty sure they have 3. They are cast heads. From what I remember, when talking to Marshal engines (the builder) they used early vortec heads and early to mid 80's crank.
BMW & ASE Master Certified
I grabed a set of brackets off of a 90 ish camaro v-8... modified them of course to fit a big block, but heres some pictures of the brackets installed
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 03-27-2010 at 11:44 PM. |
#13 |
Well I don't know what I'm going to do yet. If every thing goes right I might have enough for a nice set up from March.
#14 |
haha, ford guys...
what if you lack accessory holes in the heads??? what then? pics!?
#15 |
One day...
Ouch, March is proud of their stuff looks really good though.. i like the factory setups plus its cheap
![]() Last edited by scotts62; 03-28-2010 at 01:10 AM. |
#16 |
I have the same Blueprint engine that you have. I bought the Serpentine belt system straight from GM. It fit with no problems.
71 Chevy Stepside 377/350 |
#17 |
18 Till I Die
Why do you have to change the water pump? Do you need the new A/C compressor too or just the A/C lines?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#18 |
Hey, I can get the serpentine brackets to you this week. I'm free after Tues. |
#19 |
basically there isnt enough belt on the crank pulley... if you have any/a lot of ower good change your gonna have belt slip... heres a picture from alldata. you could also tell from the pictues of my setup how it goes around the a/c alt, ps and w/p.
as far as why you need a new water pump its becuase with a serpentine belt setup, the water pump spins the opposite direction... the water pumps are sometimes called reverse rotation pumps..
#20 |
Do you have a link for their system? I wonder if it's cheaper then the March system I'm looking at (349)?
#21 |
PM me your number. I'll call you Wed. If I can get a factory set up done cheap I'll go that route. But I don't have ac so I don't know what it will look like.
#22 |
The gm factory system comes with all bolts and brackets as well as a new water pump,new alternator and a power steering pump. I believe the system is in the 600 dollar neighborhood w/o a/c and a bit more with
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#23 |
Here is the one I bought. Like was said above, you have to use a reverse rotation water pump. So the really nice waterpump that comes with the motor can't be used. http://www.summitracing.com/parts/NAL-12497698/
#24 |
18 Till I Die
Well I guess im gonna keep the old belts cause I just put a new pump on 3 months ago...
#25 |
IT Guy/ Father/ Chevy lover
My setup came off of a chevy van works great.
