Old 03-14-2010, 11:25 PM   #1
winchster
winchster's Avatar
Question Fender brace question
Can somebody tell me what stock part is structurally deficient to make the support rods necessary?
Edit: '49 3100 by the way
Edit: For clarification I'm asking about the rods from the firewall to the fenders. Not the fender supports.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 03-15-2010, 12:36 AM   #2
cajundragger
Re: Fender brace question
I dont have the firewall to fenders and all my stuff is fine.
I did make brackets that bolt the bottom of the grille to the frame. This helped a ton with a bouncy front end. solid as a rock now.
cajundragger is offline   Reply With Quote
Old 03-15-2010, 01:03 AM   #3
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
I'm thinking the radiator might be a little heavy to only be secured down low. The stuff attached to it is really supported by it, not the other way around.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 03-15-2010, 08:14 AM   #4
Dan Bowles
AD Addict
They are a bit triangulated to help keep the front end centered. Remember, there were "adjustment" slots in the bottom and you are hoping everything stays in one place but the fenders/rad/cab basically make it a box and it will flex as it is going down the road. To keep it square, the triangles are used.
When doing an S10 type swap, mounting the radiator to the frame pretty much keeps the side to side forces down to a minimum but you still run the risk of the top twisting side to side. With the new suspension, most of this is eliminated unless you are driving in very harsh washboard type conditions. The old straight axle would have you bouncing around and twisting.
Dan Bowles is offline   Reply With Quote
Old 03-15-2010, 01:09 PM   #5
mylow53
mylow53's Avatar
other than the fender to cab bolts those rods anchor the cab to the entire front end. if their is flex in the cab/front end motion and the rods are off your fenders will be doing the flexing. have you ever ridden in the bed of a truck and see the cab move differently the the bed? i would assume those rods help with the flexing issue. my cab had multiple spider cracks around the cab bolt holes....
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 03-15-2010, 09:50 PM   #6
winchster
winchster's Avatar
I was just curious seeing how b****in products says you can do away with them if you use their core support and inner fender. I'm having issues with my build and was thinking of fabbing a honest to God core support then since my inners are useless fabbing up some new ones. I figured if it has a real core support like a modern truck then I wouldn't need the rods. They don't really bother me I was just seeking enlightenment.
Old 03-16-2010, 07:01 AM   #7
Dan Bowles
AD Addict
We don't have many miles on my son's truck but so far, so good. I think a good anchoring system, combined with the stiffer frame (the ladder frames were MEANT to flex as part of the "suspension" of the original truck) you'll be in good shape.
Old 03-16-2010, 03:32 PM   #8
mr48chev
mr48chev's Avatar
I have/had a lot of miles on my 48 and ran without them for a long time. From experience I can well say that they help keep the front end sheetmetal aligned and also help some with keeping the squeaks down by stabilizing the fenders.
I'm not familiar enough with that particular aftermarket core support except to say that it does look interesting from a lot of standpoints and I may need to run one before I am done due to a couple of mods I have planned.
I won't go as far as saying a guy has to run those rods on his truck but I for sure won't run a truck without them again.
Old 03-16-2010, 04:01 PM   #9
winchster
winchster's Avatar
Guess I will keep 'em. I still have to figure out the core support and inner fenders though. Thanks guys.
