Old 03-14-2010, 11:39 PM   #1
blazin
72 blazer body mount torque specs
does anyone know the body mount torque specs?? the set i bought didnt come with them.
blazin is offline   Reply With Quote
Old 03-15-2010, 12:12 AM   #2
blazin
Re: 72 blazer body mount torque specs
i know ive seen the specs on here and now i cant seem to find them.. i am ready to install them and dont want to till i have the torque specs.. someone please take pitty on me
Old 03-15-2010, 12:18 AM   #3
63chevyll
gets board easy.......
63chevyll's Avatar
i would just tighten evenly and tighten by hand/feel
I think they are 1/2 bolts, so 80-100Ft/Lbs should be within spec
63chevyll is offline   Reply With Quote
Old 03-15-2010, 12:21 AM   #4
blazin
i thought i read that if you tighten them to much it will squish the rubber mounts. from what i remember its around 20 to 50ft/lbs. i really dont want to F anything up. i tried searching the fax thread and cant find them and with the 60 sec wait between searchs.. its killing me.
Old 03-15-2010, 01:40 AM   #5
72truckman
72truckman's Avatar
tighten till the rubber bushings are slighttly bulged on the sides but not collapsed
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 03-15-2010, 05:55 AM   #6
Burt4x4
Burt4x4's Avatar
I would use nylon locking nuts and tighten like truckman said. Too tight and they won't "work" right...I never used a torque setting for thoes mounts. Just snugg um up tell you see slight buldge. Double checkum all after yer first ride.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-15-2010, 10:25 AM   #7
skidder111
skidder111's Avatar
Aren't you supposed to tighten them until the lower washer and the body mount sandwiches the steel core inside the rubber mounts? I thought this should preload the rubber mounts.
skidder111 is offline   Reply With Quote
Old 03-15-2010, 12:12 PM   #8
blazintowers
blazintowers's Avatar
thats how I did mine, tighten until the washer bottoms out on the steel sleeve insert, this keeps the rubber mount from squashing. then drive it for a week or so and retighten everything up again. if you don't use nylock nuts put a dab of weatherstip adhesive on the end of the nut and first couple of threads of the bolt after tightening to keep the nut from coming loose.
blazintowers is offline   Reply With Quote
Old 03-15-2010, 01:21 PM   #9
SOON2BLAZE
SOON2BLAZE's Avatar
This was in the FAQ section from frenchblue: http://67-72chevytrucks.com/vboard/s...d.php?t=195985 does not apply to poly bushing IIRC
SOON2BLAZE is offline   Reply With Quote
Old 03-15-2010, 06:44 PM   #10
blazin
thanx guys.
Old 03-15-2010, 08:45 PM   #11
63chevyll
63chevyll's Avatar
sorry, i shoulda asked, I assumed you had urithane or an afertmarket mount.
with the price difference i never even buy stock body mounts anymore
Old 03-15-2010, 08:50 PM   #12
blazin
no its stock body mounts. paid 250 canadian. i wanted the stock.
Old 03-15-2010, 09:18 PM   #13
PHAT TONY
PHAT TONY's Avatar
The 'structions with mine said 25 ft/pnds, I don't know how many I dun, slight bulge, unlike my gut!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
