03-15-2010, 01:30 AM | #1 |
pushrod BBC problem
So i went to put in my pushrod today to adjust my valves and i guess i ordered the wrong pushrods. The ones i ordered are 3/8 of a inch thick. They are to big for my guideplates. I can not seem to find any pushrods that are thinner. coul someone help me out here.
03-15-2010, 09:59 AM | #2 |
Re: pushrod BBC problem
If you've got stock guide plates, chances are they are 5/16". You'd be better off to replace your guide plates with 3/8"...Stick with the larger pushrods/guides if you can.
Here's some Comp brand. http://www.competitionproducts.com/C...ctinfo/4806-8/
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
03-15-2010, 10:16 AM | #3 |
Ok and replacing the guideplates is that something i can do in the garage. Is it as simple as screwing out the studs and then sliding these new guideplates in and torque the studs?
I have just never pulled a rocker stud out before? |
03-15-2010, 03:59 PM | #4 |
Yup unscrew the studs,swap the plates and torque em back down.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-16-2010, 09:31 AM | #5 |
Yep, break all the studs loose, pull the guide plates out. Put a few drops of oil on the rocker stud threads, then install new guide plates and studs. Torque the studs to 50 ft. lbs.
03-16-2010, 11:51 AM | #6 |
Alright thanks guys, Lock tite or anything?
03-16-2010, 06:25 PM | #7 |
No loctite, just clean oil.
