Old 03-15-2010, 01:45 AM   #1
c10seconds
c10seconds's Avatar
What do I need?? To get 4 3/4 lug pattern
I have a 73+ front disc suspension with a 5x5 bolt pattern and I need to get it to a 4 3/4 pattern. Im not sure what suspension parts will fit with what and I DONT want wheel adapters. Anybody know what I need to do?
c10seconds is offline   Reply With Quote
Old 03-15-2010, 01:48 AM   #2
jorgensensc
jorgensensc's Avatar
Re: What do I need?? To get 4 3/4 lug pattern
Really the only way that is feasible is to get your front rotors redrilled as well as your back axles. then you can get rear drums for a van (mid-late seventies if i recall). It is the same drum part number as the '56 Bel Air front drums.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-15-2010, 01:51 AM   #3
c10seconds
c10seconds's Avatar
Ive already got the rear axle redrilled and put back together. can I order new discs with 4 3/4 that will fit with the 73+ spindle and caliper?
Old 03-15-2010, 04:38 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you can try car parts, but I don't know that they'll fit on a truck.
