Old 03-15-2010, 10:53 AM   #1
TomJohnston
TomJohnston's Avatar
auto 350 doesn't want to shift into park
OK, so I took the truck out for the first time this weekend. The audiosonic plus transparent muffler I installed last year still sounds as great as ever!
But the shift lever is really sticky, like there is a stop for it that has somehow been adjusted to be in the way. I have to really yank hard on it to get it from park to any drive gear. going back into park is even worse. Any suggestions?
Dad's 1970 Chevy C10 Custom
350, auto, armstrong power windows and doorlocks
"My carbon footprint is bigger than yours"
TomJohnston is offline   Reply With Quote
Old 03-15-2010, 10:58 AM   #2
kwmech
Re: auto 350 doesn't want to shift into park
Make sure that the trans is in park. Set the brake. Loosed the adjustment nut at the linkage. Put the shifter in park, tighten nut. Test drive
Old 03-15-2010, 01:50 PM   #3
junkman
My column is the same way, It is terribly hard to pull the lever back to get it into and out of park. There is a little notch right outside the firewall that I guess is to keep you from just going into park without pulling the lever. I have sprayed the area down several times with penetrating oil, and I can move it now, but I guess it all needs to come apart.
junkman is offline   Reply With Quote
Old 03-15-2010, 02:42 PM   #4
67chevemall
67chevemall's Avatar
Adj linkage....get a buddy in the cab and you under the truck
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-15-2010, 03:13 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Block the wheels while your under the truck. Trust me on that.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-15-2010, 03:27 PM   #6
cdowns
cdowns's Avatar
spraying the crap out of the lever and all moving parts in the column and linkage to clean and lubricate things is a nice thing to do to 40year old moving parts
Old 03-15-2010, 03:27 PM   #7
Pickupmanx2
Lube, lube and more lube,,,,
I did that on my 70 C10,,,did wonders, was just dry
SEMPER FI
96 F350 CC/4X/7.3/ZF5
77 F150 SB/4X/NP435/NP205
70 C10 400/400
63 F250 4X/T98/NP205
Pickupmanx2 is offline   Reply With Quote
Old 03-15-2010, 04:03 PM   #8
TomJohnston
like my ankles
thanks guys, I'll get the grease gun or the 10W40 or olive oil or whatever it takes to make that thing slippery.
