Old 03-15-2010, 11:56 AM   #1
Mike Bradbury
Mike Bradbury's Avatar
Window trim
I was at the "big three" swap meet in San Diego a couple of weekends ago and bought some window trim that I have been needing for the truck. It is the rainy season here now and wanted to keep the water from getting inside the door, since the original was all rotted out.
I was disappointed to find that the new was just about as effective as the old rotted stuff. It did not come close to contacting the window, and let the water just roll in. I am looking for the type that actually contacts the window and seals the water out, not just stops the rattles. Does any one know where I can get some of the good trim?
The felt that surrounds the window in the channel was fine and installed easy, but the inside and outside rubber and felt where you rest your arm were not what I wanted. I was looking for the scrubbers that look more like a windshield wiper and contact the window in an upwards radius and prevent the rain from soaking the inside of the door.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 03-15-2010, 03:32 PM   #2
cdowns
cdowns's Avatar
Re: Window trim
door windows aint water tight thats why the general put drains in the bottom of the door
Old 03-15-2010, 03:48 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: Window trim
Some of the seals are better quality then others. Classic Heartbeat has some good ones. If it's a pre '72 the door might have spread a little bit as well.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-15-2010, 08:19 PM   #4
AirSpeed
AirSpeed's Avatar
Re: Window trim
For my 69 C10 I bought some from Classic Parts, the inside is made with the felt, the outside has the rubber wiper type trim. It doesnt really rub against the window very tight but it seems to last longer the the felt on the outside. I check the drains every once in a while, you would be surprised how much stuff builds up in the bottom and plugs up the holes!
Aaron
AirSpeed is offline   Reply With Quote
Old 03-18-2010, 12:17 AM   #5
vexvader
1967 C10 SWB
vexvader's Avatar
Re: Window trim
I bought mine from LMC and they work Great!!! No leaks.
Vex
vexvader is offline   Reply With Quote
Old 03-18-2010, 12:18 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
Re: Window trim
Vex
I had some from LMC, but they didn't last in the SoCal sunshine. Cracked pretty quickly. The stuff I got from Wes is pretty nice in comparison.
Beat it to fit,
