Old 03-15-2010, 05:11 PM   #1
bradf74
79 convert from manual to power brakes... What do I need
My 79 manual master cylinder has gone out. No fliud/air coming out of the front resevior. Since I have to replace it anyway... what do I need to convert to power brakes? Besides the obvious master cylinder and brake booster. What about the pedal itself? The prop valve? It has disc in front and drum in rear.
bradf74 is offline   Reply With Quote
Old 03-15-2010, 06:47 PM   #2
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: 79 convert from manual to power brakes... What do I need
Nothing....just the booster and new master.
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 03-15-2010, 07:40 PM   #3
bradf74
DOes the pedal have another hole for the power MC? The leverage is different on the manual vs. power right?
Old 03-15-2010, 08:11 PM   #4
James McClure
One shot, one kill.
You will need the pedal from a power brake vehicle. If you use the manual brake pedal the brakes will be SUPER touchy. When you get the booster make sure the "apply" rod is in it. It's a little rod in the center of booster held in place by a rubber disc that pushes the piston in the master cyl. Other than that, all you'll need is time to do it carefully.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-15-2010, 09:31 PM   #5
bradf74
What years fit what? I have looked online and do not see any ones new for sale. Anybody got one?
