Old 03-15-2010, 05:47 PM   #1
4montecarlo
smooth roll pan and tag
i want a roll pan for my 84 truck. i want to get the grant kustoms 3 piece but at 180 is more than i want to spend. i have found the smooth pan with no tag cutout for only 80, where would i put my tag?
thanks
matt
4montecarlo is offline   Reply With Quote
Old 03-15-2010, 05:51 PM   #2
SevenSeries
Re: smooth roll pan and tag
My bad...Misread.
With enough time and money, you can do anything
Quoted from my father
1976 C-10 Project
SevenSeries is offline   Reply With Quote
Old 03-15-2010, 06:01 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Matt,
Take a look here; http://www.mar-k.com/catalog/catalog.asp they are a site vendor and members get a discount so I hear.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-15-2010, 06:10 PM   #4
mwooten92
mwooten92's Avatar
thanks
matt
some people mold it into the tail gate
85 C-10 ShortBoxChevy!
Build Thread of my 85' C-10
http://67-72chevytrucks.com/vboard/s...d.php?t=367919
mwooten92 is offline   Reply With Quote
Old 03-15-2010, 06:45 PM   #5
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Uh....make one? Some 18-20 Gauge metal from the hardware store, cut oversize the "depth" ya want the plate to "sink", then bend the sides using C-clamps clamped to a bench....unless ya have a freind with a sheetmetal brake....cut out yer pan for the new insert ya just made and weld the sucker in.....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 03-15-2010, 07:56 PM   #6
thrtsxchambers
thrtsxchambers's Avatar
I have mine in the window until I decide what to do with mine. Planning on the kit that slides it into to top of the bed rail, but it's not cheap so I may find the components and build my own.
thrtsxchambers is offline   Reply With Quote
Old 03-15-2010, 08:27 PM   #7
Restrorob
Restrorob's Avatar
On that note check THIS out, Could be mounted under a roll pan with a little fab work....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-15-2010, 11:07 PM   #8
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
The flip license plates are a great little item. They are on a lot of hot rods. But I have seen a couple things go wrong while using them. People air out on top of them without folding them first, either smashing or dragging them off. Or people getting pulled over for forgetting to expose them again before going down the road. Just something to keep in mind.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-16-2010, 04:30 PM   #9
thrtsxchambers
That would be my luck, I would forget to raise it and crush the tag. I've seen those and like them but I think I would have bad luck with that one. The one I want is $250 but I think I could make one for uder $100 easy and just have it go between the bed and cab or try to tuck it in the rail.
Old 03-16-2010, 04:44 PM   #10
jayman68
Fun Stuff
jayman68's Avatar
Just get the motorized flip one and have it activate when you turn on the key.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 03-16-2010, 08:51 PM   #11
Restrorob
Restrorob's Avatar
Well, My truck isn't bagged so I don't have to worry about rippin it off. But I will spend that $140 plus on something else since I have everything sitting out the the shop to throw one together in little over a hour.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-17-2010, 01:11 AM   #12
thrtsxchambers
yea, the one I want is motorized and can be controlled with the ignition and would be great as long as it's not bagged
Old 03-17-2010, 11:10 AM   #13
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I've got the stuff to do an auto-flip down on my truck, but really don't have anyplace to put it where it won't look goofy when flipped down. I'm liking the Mustang idea that slide up.
I also have a Lexan window with the plate box in molded into it, but I'm not too big on that either.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-17-2010, 11:13 AM   #14
4montecarlo
good ideas, keep them coming
thanks
matt
