Old 03-15-2010, 09:54 PM   #1
Estanley
Estanley's Avatar
Bouncing speedo needle
I have an 81 4x4 and the speedo needle bounces until it gets up to hwy speed and it reads about 15 to 20 mph fast. I"m running stock heigth tires. Can anyone tell me how to stop the bouncing and make it show the correct speed?
Estanley is offline   Reply With Quote
Old 03-15-2010, 09:59 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Bouncing speedo needle
The bouncing is almost always caused by a dry cable. Lube the cable up as best you can and see if that works. Sometimes you can actually pull the whole cable out of the sleeve, lube it up, and put it all back together.
It could solve the problem with it being off, but if it's still of when it doesn't bounce anymore, you will probably need a new gear for the transfer case. It's a pretty easy fix.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-16-2010, 03:13 PM   #3
felixthecatjr
felixthecatjr's Avatar
Any particular lube to use for the cable?
felixthecatjr is offline   Reply With Quote
Old 03-16-2010, 03:17 PM   #4
vtwinsport
vtwinsport's Avatar
You might have in issue with the gears in the transmission. I replaced mine for that same reason (2wd) and it still bounces. I am leaking trans oil from that spot though and I know there's worn out parts back there cause it doesn fit well anymore.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 03-16-2010, 07:12 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
man, mine does it too (sometimes)
i will be ripping down the highway and my speedo starts going ape!
after a few clicks it usually resumes normal function
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-17-2010, 07:58 AM   #6
Turbo85GMC
Turbo85GMC's Avatar
+1 for the speedo cable. Check it for any sharp bends, adjust the routing as straight as possible, lube, and if all that doesn't help, replace.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
