Eat My Rust
Joints too wide... by hundredths of an inch!
Has anyone else had a problem with a brand of joints being too wide (cap to cap, not cap diameter) by literally hundredths of an inch? Don't remember the brand, but what ever advanced autoparts sells. Both joints didn't fit, and this is for the joint at the transmission... But the part number says for all 3 so it's not like anything is being mixed up.
What's the larger chance, the drive shaft being tweaked... Or having the wrong u-joint (by the slimmest of margins)? Parts hunting has gotten ridiculous on this truck. Last edited by texanidiot25; 03-15-2010 at 11:29 PM. |
Shake and Bake!
![]() Join Date: Feb 2010
Re: Joints too wide... by hundredths of an inch!
Not sure what brand they gave you, but if you can find a set of Spicer U joints with the grease zerk fitting, they are top notch in my experiences. A little more $, but well spent.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
Eat My Rust
Red and blue box is what I recall. The truck is at the dealership my dad works at.
This is frustrating. Stock replacement doesn't fit... But the adapter u-joint we put in last month to fit a 3/4 ton drive shaft to a C10 rear, that was measured with a damn tape measure, fit on the first try! Shoulda taken less than an hour. Spent nearly 3 hours since the needle bearings kept wanting to fall outta place too. So it took several tries before we even got the clips in to find out that the thing didn't fit. |
They may be trying to sell you a Saginaw S44 joint like the later model GM trucks use instead of a Spicer 1310 or 1350 series (not sure what joint you are looking for). They are similar sized, but different from the Saginaw joints.
Tim |
I think advance's brand are PDQ. These trucks took a lot of different size u-joints dependin one engine, trans, rear end, 1 or 2 piece shaft, etc. Parts guy could have looked it up wrong. I know auto zone's duralast u-joints fit for sure, have used many of them. Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
Under Construction
I had similar issues with o'reilleys and autozone ujoints. after trying a couple i went to the driveshaft shop and dropped 30.00 for two spicers and they worked pefectly...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Eat My Rust
Yeah, PDQs. I was there watching the screen with the advanced autoparts guy as he pulled up the part number. 3sp 2wd C20 joints had the same part # for auto or manual 3 spd, and for all three locations.
The truck is a heavy half ton, former D60, so that's the reason for the C20 drive shaft btw. I'll keep spicer in mind in the future. But we were still furious that the factory sized one didn't fit... and yet the one we measured with a cheap-o tape measure that's a custom two-sized u-joint fit the first time! ![]() Murphy knows my truck too well. Last edited by texanidiot25; 03-16-2010 at 01:12 PM. |
![]() Join Date: Jan 2008
For what it's worth, I try to write part#, manufacturer, and where you bought it, on hard to find parts for future reference. Good luck!
Precision universal joints is all I use
Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
mini truck racer
Houston drivetrain off the loop is a Spicer dealer . Call Daunte and he'll fix you up . I have also used Percision , but Spicer are the best imo. Hope one of the needles didn't fall over taking up the extra space . Did you end up fixing the D60 ?
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 03-16-2010 at 10:42 PM. |
I had the same frekkin' problem with the U-joints from Adv Auto Parts & AutoZone. I was soooo pissed. I thought I had somehow managed to bend things up pressing the old joints out. I ended up sanding the retaining clips to get them to fit.
Glad I'm not the only one to have this problem.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Who needs sleep...
![]() Join Date: Aug 2009
Dang, Wish this thread was around three weeks ago...
O'Reilly and AutoZone joints, two spots in the shaft were both too damn big. Messed around for three nights, screwed up two joints, finally took it to a local trans shop. Guy took .010 off the top of the cap, just enough to make the letters shiny, worked great. We got back and had to do the same to 1 other one to get it together. I'd rather sand a little off the ridge on the cap than on the clip, seems more structurally sound to me. Trip |
#13 | |
Eat My Rust
![]() 4 u-joints, and only one fit.. Anyways, I'd stay away from the advanced autoparts brand in the future. Shoulda gone to Napa, they have spicer. ![]() Graywolf- My dad thought that maybe he'd bent the yoke too, but, he had said in years he did drive-line work, that had never happened. Ruled that one out too, but you're not alone on that either ![]() Last edited by texanidiot25; 04-12-2010 at 12:54 AM. |
