Old 03-16-2010, 12:47 AM   #1
Baged72
Baged72's Avatar
What is our dash made out of???
EDIT** The gauge cluster not dash......
I tried Plastic Welding some custom gauges to the back of my gauge cluster but they seem to keep breaking off, and the only thing on the back of the package that it wont bond to is # Polypropylene plastic & Polyethylene plastic is this either of those?
This stuff is 10,000 PSI strength
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 03-16-2010, 01:41 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: What is our dash made out of???
I'm pretty sure it's ABS plastic. http://en.wikipedia.org/wiki/Acrylon...adiene_styrene
Maybe epoxy will work?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-16-2010, 03:01 PM   #3
Fitz
[QUOTE=Brad;3863751]I'm pretty sure it's ABS plastic. QUOTE]
Nope, ABS is not pourous enough to give epoxy any tooth but if you go to Home Depot or any hardware store and buy ABS plumbers glue (for black plastic pipe) it will do the trick. Just remember, this is a solvent cement...it dissolves the ABS then when the volatile solvent evaporates it allows it to solidify back into the original plastic. In short that means it's a permanent bond and you do not want to get it on anything you don't want melted together.
Fitz is offline   Reply With Quote
Old 03-16-2010, 03:39 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Using a solvent cement will work if both plastics are bondible, or will melt with the same solvent. Example PVC (Polyvinyl chloride), ABS (Acrylonitrile butadiene styrene) are 2 chemiclay different compounds based on 2 seperate base materials. (one chlorine based and the other styrene based) This is why both examples that I gave have different adheisives. Solvent base adheisives actualy work by melting the materials that are to be bonded and the twisting of the materials together actualy mixes the two surfaces together and making them one. This is why glues that stick to surfaces are better for adhearing two different types of plastic. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-16-2010, 05:28 PM   #5
mbgmike
This will work.
Does not hurt to rough it up some to.I worked for Rohm and Haas (Plexiglass) and GE ( lexan) and other companies making plastic. Their are other brands of solvent, many of them that will work.
mbgmike is offline   Reply With Quote
Old 03-17-2010, 12:31 AM   #6
Baged72
Baged72's Avatar
Is this stuff safe to put on my gauges?? I am not worried about it not coming off i dont want it to, and if i do need it off i can always die grind it correct??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 03-18-2010, 02:13 AM   #7
Brad
Brad's Avatar
I forgot to mention that MEKP is what works with ABS plastic and acrylic. Be aware that it's really bad for your health but you can get it at any hardware store.
Old 03-18-2010, 10:13 PM   #8
Baged72
Baged72's Avatar
I dont plan on eating it, thanks.....
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 03-18-2010, 10:29 PM   #9
midevil1
ShortBus KingPin
midevil1's Avatar
Come on man.... You know you ate the Elmer's "MINTY" Paste in grade school.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 03-18-2010, 10:38 PM   #10
knsmodels
I make Models
knsmodels's Avatar
He is referring to the fumes.......it will hurt ya......
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 03-18-2010, 11:16 PM   #11
Baged72
Baged72's Avatar
I noticed my gauges have an aluminum ring they are auto meter sport comp 1's will this stuff still bond to the aluminum "i think it is" & the plastic??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
