Old 03-16-2010, 02:31 AM   #1
MARCUS'S 68
Help with my 80 c10 olds 455
Alright peeps I just picked up a very very nice 80 SWB for a very very cheap price. Problem is it has a 455 in it the scoop I got was the previous owner was driving it one day and it just died when he went to crank it over it did nothing. First thing I did was pulled the starter and it was froze so I replaced it and cranked the truck and the starter jumped but battery was weak put another battery in it and then all of a sudden I was not getting power to anything i wiggled the pos battery cable a she was powered up again now the the starter won't even jump I noticed the key kinda hard to turn after tearing into the column I noticed someone had been in there before everything was loose! When the starter was jumping and I turned the key foward to the on position the brake lights in the dash would dim now they aren't dimming and the starter isn't budging! I feel like the points in the ignition isn't getting contact and the module looks difficult to remove so tommorrow I am heading to the salvage yard for a whole steering column my question is am I headed in the right direction or do I need to be looking elsewhere hope someone out there can help! Thanx Members for any input!
MARCUS'S 68 is offline   Reply With Quote
Old 03-16-2010, 08:40 PM   #2
MARCUS'S 68
Re: Help with my 80 c10 olds 455
Update loose battery cable ha how bout that!
Old 03-16-2010, 08:56 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
That'll do it quite often, Good you didn't throw a lot of parts at it for nothing !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
