Old 02-04-2003, 03:01 PM   #1
paintpyro
paintpyro's Avatar
Question pinion seal replacement
Anything to watch out for on a pinion seal replacement? Anyone have any tips for gettin that bolt loose, what size is it anyways? Never done one before, rear is out and on stands. What are the basics? Seal go in dry?
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 02-04-2003, 03:39 PM   #2
72MARIO
72MARIO's Avatar
Make sure you dont collapse the sleve in there that s all I can say Get a manual that will help. impact gun to get it off. Hope this helps a bit.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-04-2003, 04:13 PM   #3
crazy longhorn
Fabricate till you "puke"
by rights, you should replace the crush sleeve when you do a seal, but a lot of guys will opt to add a .030-.040 shim between the sleeve & yolk, & pull it back up. There is no tork setting on the nut, but it needs to be tightened to give about 7-9 inch lbs of ROTATING tork on the pinion(oiled with used bearings). It would bea good idea to use blue lock tite on the nut when you reassemble. Good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-04-2003, 06:43 PM   #4
Mike C
Mike C's Avatar
The only way to do what crazylonghorn suggests is to disassmeble the diff COMPLETELY. You can only shim and/or replace the crush sleeve if you remove the pinion gear which means removing the ring gear which means removing the axle shafts. All of the guts also have to be out in order to measure the rotating torque on the pinion bearings as well since the diff and ring gear will skew that number. This is not necessary for a pinion seal replacement. Trust me, if you take it to the dealer for a pinion seal replacement, they sure won't! Just remove the yoke, remove the old seal, tap in the new seal, then replace the yoke. Tighten it down until there is no fore/aft play. (actually, there should be none anyhow since the press fit pinion bearings were not disturbed.) DO NOT use an impact...very easy to overcrush the sleeve. If I was guessing, torquing to 40#ft should be good. You can use a pipe wrench to hold the yoke from turning to loosen or tighten. It is a good idea to replace the pinion nut, at minimum re-peen the top with a hammer whack.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-04-2003, 06:53 PM   #5
crazy longhorn
Yup, Mike C is right on......that rotating tork figure is to be with the diff completely disassembled....thanks for bringing that up Mike
