Windshield removal
I am looking to swap the windshield from my Blazer to my truck for the antenna in the windshield. Is this an easy process that can be done in a couple of hours?
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
Right in front of you.
Re: Windshield removal
Pretty easy.....I've swapped windsheilds in under an hour.
It helps to have an extra person and glass tools...but it can still be done easily by yourself and with a few, dull screwdrivers...
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
use plenty of WD-40 around the seal to remove it
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Thanks guys. Here is another stupid question: Can I re-use the window rubber or do I need to buy new ones...................
I had mine replaced at a shop and the re-used my gasket. I guess it all depends on the condition of it.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Yes....and most times, the factory rubber fits better than the repop stuff anyway. You'll know when ya take out the glass....if the rubber seems pretty stiff, it's time for new rubber.
just went down that road a month ago( broke 2 doner windshields trying to get them in) you need some nylon glass spoons and a clear mind and not be in a hurry if you try to do it yourself! that seal will be very tight on the corners. from experience ask your local glass shop how much $ to install, just my 2 cents!
![]() Join Date: Jun 2007
I just removed a bad windshield in my 84 and the seal was locked on had to cut it to get it out. tried installing another used windshield with a new seal and it busted. If your glass is old and the seal is old you might have to replace both. I found a local glass place that will come to the house and install and supply a new tinted windshield with antenna using my new seal for 125.00 they also have a specialty tool for installing the lock.
