Old 03-16-2010, 01:11 PM   #1
chockblockjed
chockblockjed's Avatar
81' c10 sm465
Has anyone with an early 80's C10 swapped out the straight 6 250 and three on the tree for a 350 and SM465. I have already swapped out the engine and want to lose the column shifted saginaw for an SM465. My donor 350 came out of an 81 blazer, but i used the clutch, flywheel, and bellhousing from my straight six. So, should an early 80's SM465 bolt right in with a quick cut to the hump or is there more involved?
1981 C10 SWB 350 (in progress) 3 on the Tree "Old Bess"
1996 K3500 Crew Cab 454 4L80E "Family Camper"
2002 GMC 1500 Yukon XL 4WD "Wife's Ride"
chockblockjed is offline   Reply With Quote
Old 03-16-2010, 03:32 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: 81' c10 sm465
I've never owned a column shifted truck before, but I'd guess you'd be fine to get away with just a hole cut in the floor. I imagine that the clutch stuff would all remain the same between the two transmissions.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
