03-16-2010, 05:54 PM | #1 |
70 GMC Transmission Advice
I am going to pull the transmission on my truck this weekend. Looking for any advice or information anyone may have.
1970 GMC Shortbed 402 BB with a Turbo 400 Trans. Any help would be greatly appreciated! Dusty
Dustydog 1940 Ford 2D SDN 1970 GMC SB 2004 C5 Vette |
03-16-2010, 06:17 PM | #2 |
Re: 70 GMC Transmission Advice
Get a good book & a good jack. Are you asking for some one to physically come help or step by step directions?
03-16-2010, 06:23 PM | #3 |
Sooo....what are you looking to do? The turbo 400 can be built very strong with the right sprags....it will be much stronger than a 700R4 and you're running a big block....
03-16-2010, 06:45 PM | #4 |
Thanks,
I am going to pull it myself with my sons help. I have a trans shop that is going to rebuild it for me. Just looking for any advice on tricks for pulling it. Dusty
03-16-2010, 07:25 PM | #5 |
get a good trans jack and have the truck up high enuf to get the trans out from under the truck. drain the oil first.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
03-16-2010, 07:29 PM | #6 |
Between Trucks...
Now would be a good time to get a transmission pan with a drain plug. Makes filter changes a lot less messy.
Beat it to fit, Paint it to match... |
03-16-2010, 08:00 PM | #7 |
For those that have removed the tranny, any helpful info that may help during the removal such as the links, speedo cable, unbolting, drive shaft removal, plug, etc...? I have never removed one so I'm interested too. Thanks
03-16-2010, 10:24 PM | #8 |
Don't pull the driveshaft out until your ready to catch the tranny fluid coming out the tail shaft.
Don't force the re-install. Make sure the converter is in place before bolting it back up. It should click in 3 times as you spin and insert into tranny.
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs 1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI 2007 Chevy Corvette ZO6 427ci 505HP |
