Old 03-16-2010, 06:02 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
when using a 700r4 trans do i need adapter on speedo cable?
my 71 GMC has a 700r4 trans. the speedometer that was on the truck originally will not screw into the 700r4. the truc originally had a TH400 in it. do i need a new aftermarket cable or some kind of adapter on the cable to fit in the trans? thanks
gmc1971harwich is offline   Reply With Quote
Old 03-16-2010, 06:24 PM   #2
michael bustamante
michael bustamante's Avatar
Re: when using a 700r4 trans do i need adapter on speedo cable?
good question. subscribed, I believe you need a turbo 350 cable though buuuut I could be wrong, I havent tried hooking mine up yet
1967custom
michael bustamante is offline   Reply With Quote
Old 03-16-2010, 07:13 PM   #3
cparman
sharp as a marble
I have done this swap several times, and the existing speedo cable should screw onto the 700r4 trans. Just got finished doing a 200r4, and it screwed right on.
cparman is offline   Reply With Quote
Old 03-16-2010, 07:17 PM   #4
ratpackv8sonly
ratpackv8sonly's Avatar
Yup should just screw right in. TH-350 to 700R4 to 4spd manual now and all with the same spedo cable.
ratpackv8sonly is offline   Reply With Quote
Old 03-16-2010, 07:54 PM   #5
michael bustamante
isint a 400 speedo cable different from the turbo 350 though?
1967custom
Old 03-16-2010, 07:54 PM   #6
LEEVON
LEEVON's Avatar
Later 700R4's have the VSS sender, older ones have the speedo gears. The tailshafts can easily be swapped and the TH400 should screw right in. Go to the parts store and get a 4wd speedo cable, they're a bit longer and fit perfect.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-16-2010, 11:17 PM   #7
gmc1971harwich
hey sorry guys but there was originaly a th350 not th400, as for what year the 700r4 is il try to see if i can get some numbers off of it. do u guys know where the numbers would be on the case? thanks
