Old 03-16-2010, 06:50 PM   #1
50mercfan
50mercfan's Avatar
Need Help : Accelerator cable install
I just bought a 72 with a bocthed up throttle cable. I bought a new cable but can't figure out how to get the cable through the pedal arm. can anyone help? i did a search and could find the answer.
50mercfan is offline   Reply With Quote
Old 03-16-2010, 07:35 PM   #2
JimKshortstep4x4
Re: Need Help : Accelerator cable install
There is a plastic sleeve on the cable that keeps it from going through the hole in the pedal arm. Pull the cable out and push the sleeve out of the hole. There is a slot in the plastic sleeve that will allow you to remove the sleeve. Once the sleeve is off of the cable the end of the cable can be pulled through the hole in the pedal arm.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-16-2010, 11:55 PM   #3
50mercfan
50mercfan's Avatar
thanks jim, my new one has a much larger sleeve, with no slot. do i just use the old sleeve?
Old 03-17-2010, 05:08 AM   #4
JimKshortstep4x4
Yes, just use the old sleeve. The new one must be made for a slotted pedal arm.
Jim
