03-16-2010, 07:59 PM | #1 |
Grounding plastic fuel cells
I am putting a plastic fuel cell in my 67's bed. Everything i read says to properly ground it. How do you ground a plastic fuel cell? It has an alunimum neck bolted on. I could ground one of the mounting bolts. The sending unit is grounded. I cant think of anything else. Any ideas?
03-16-2010, 08:04 PM | #2 |
Re: Grounding plastic fuel cells
Hey !! where are you in hampstead ?? cool little town . anyway you need to ground the sending unit to body or frame plastic tank should have a ground installed by hot glue or 2part epoxy you will want to use a shielded gound strap to the frame or body same as the sending unit and your done.
lifted, locked, rockin |
03-16-2010, 08:19 PM | #3 |
yes run a ground from one of the mounting bolts it will prevent static sparks while fulling.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa Last edited by JDL; 03-16-2010 at 08:19 PM. |
