Shake and Bake!
![]() Join Date: Feb 2010
Is it safe to run the truck with the driveline out?
Hey guys,
Here is a question that I don't know the answer to because I have never thought about doing it before. I just pulled the driveline out of my 72 C10 with the 350/TH350 to replace the carrier bearing due to the rubber being blown out, and figured I throw some new U joints on. I have been trying to track down a whine/humming noise under light throttle and was wondering if it is safe to run it in gear up to about 1500 RPM with the driveline pulled to see if the noise is the DL or if it is in the trans? I know we have done it with our offroad rigs after breaking a rear, we would drive out with only a front, but this was just cause we had to. Maybe a stupid question, just have never done it. Thanks guys!
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
Re: Is it safe to run the truck with the driveline out?
When i bought my blazer the rear was out so we pulled the driveline and used it as a front well drive
70 SWB STEPSIDE 70 BLAZER 09 challenger |
No its not, With no yoke in the transmission the output shaft will have no support.
Shake and Bake!
There is the answer I am looking for! Thanks Cline.
72 GMC
Hey Leviticus
I'm doing the same thing on my 72 GMC. The new carrier bearing I got was not idential to the old one. The inner sleeve that is not attached is on the opposite side on the new one. My question to you is, which side of the carrier bearing are you pointing toward the front of the truck ? Not trying to hyjack your thread, but hoped you would have the answer. Thanks |
Redefining LowBudget
since your doing U joints you could do it with Just the yoke...Just be smart about it with No load that thing is going to spin up to ungodly speeds the second you put it in gear with no way to slow it......so shut it off before you put it back in park......option B would be jack it up put it on stands block the front wheels take the rear wheels off and try it....
keep in mind neither is really safe...But......it gets the job done..you probably won't find the wine with no load anyway Good Luck Kel the carrier angle should be aim back
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#7 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
72 GMC
#9 | |
Shake and Bake!
You might have gotten the wrong carrier bearing assembly. They make a "Horseshoe" type like you see on most 2 piece shafts now days and the inline one like in the pic above which is used on most of our rigs. I can't remember off hand what the horseshoe type assemblies are for but I want to say C20's or trucks with leafs, but I may be way off here. If the bolt holes don't line up, you need the other type.
72 GMC
I'll try to post pictures. The new one and the one I removed are
almost identical. You will understand my question better after I post pics. |
72 GMC
Got a few pics. The bearings are almost identical. The "loose" sleeve is
on opposite sides of the old and new bearing. Is this an issue ? And, which side of the bearing faces the front half of the driveshaft ? Thanks for the input. KEL |
#12 | |
Shake and Bake!
Kel, I'm not sure bud, the horseshoe type you have I have never dealt with on these trucks. I would think it wouldn't really matter which way, but like I said, I'm not sure. Good luck.
#13 |
72 GMC
Leviticus
Thanks for your help. I should have started a new thread instead of jumping on yours. Thought you were working with the same parts. Hopefully, someone will jump in with the right answer. Again, sorry for the hyjack, and thanks for the help. Kel |
#14 |
Shake and Bake!
Kel,
Nah man, you didn't hijack anything. Its all good, we are all here to help each other out. I know there are a lot of guys on here with the answer to your question, and you'll be back on the road in no time.
#15 |
72 GMC
Thanks for your understanding.
#16 |
