Old 03-16-2010, 11:15 PM   #1
60apache
60apache's Avatar
rear end width
I am trying to find out if the rear end width is the same with an 88 suburban as it is on the 87 down pu and does anyone know the gear ratio?
60apache is offline   Reply With Quote
Old 03-16-2010, 11:21 PM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: rear end width
6*- early 70 is the same short rear, Late 70-87 is the wider rear. rear gears really depend on a bunch of stuff.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-17-2010, 12:05 AM   #3
likaroc13
Rollin' Old Skool
Re: rear end width
i think the rear end would be the same width, considering '88 Burb was still square-body...no idea what all options for gears were
Old 03-17-2010, 12:11 AM   #4
Captainfab
60-66 Nut
Re: rear end width
The width should be the same as the late '70-'87 pickups which is 63 1/2-5/8"
As for gear ratio, IMO you'll just have to pull the rear cover. Some guys swear by counting pinion rotations per wheel rotation, but I don't have much luck with that one
