Old 03-17-2010, 01:16 AM   #1
highperf4x4
Instrument panel bulbs
Someone with more knowledge than me fill me in.
I ordered a gauge panel from Edd Dial and I had him install some purple bulbs. I thought they would look pretty cool but they turned out to be a little feminine!
I thought I would switch to some blue bulbs so I picked some up some at a local parts store and stuck them in. They are definitely blue but they're not lighting up the gauges worth a flip. I wouldn't think there was alot of difference in light between purple and blue but these won't work. The blue bulbs I got were slightly shorter than the purple ones that Edd put in but other than that, they appeared to be the same. Is there a specific bulb that works better?
highperf4x4 is offline   Reply With Quote
Old 03-17-2010, 02:28 AM   #2
Racinaround
Racinaround's Avatar
Re: Instrument panel bulbs
Heres a Bulb Chart
1972 CHEVROLET All Light Trucks
High & low beam headlamp
H6024
H6024ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6024XV XtraVision Halogen - The Brighter Light
H6024CB Cool Blue Halogen - The Whiter Light
Parking light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157
Rear turn signal
1157
Tail light
1157
Stop light
1157
License plate
Assembly
Back up light
1295
1295
199
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
97
Step/Courtesy light
211-2
211-2LL Long Life Upgrade: Up to twice the life of the standard lamp
Instrument-general
1445
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
Hi-beam indicator
194
____________________________________________________
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 03-17-2010, 10:10 AM   #3
Orange
Licensed to Thrill!
Orange's Avatar
If you want them to be bright and colored, go with LED's.
http://www.superbrightleds.com/cgi-b...ini-wedge.html
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-17-2010, 07:44 PM   #4
highperf4x4
It says on that website that the leds are not brighter than a filamnet bulb.
"Brightness of LED Car Bulbs
LED bulbs are generally not as bright as standard incandescent bulbs, they have many advantages over filament bulbs (longer life, faster on/off times, lower power consumption, more vivid colors) but brightness is not one of them."
It also says that the more leds in the bulb the brighter it will be but it doesn't really specify which ones. Do you have leds in your dash or pics you can show me?
Old 03-17-2010, 07:46 PM   #5
highperf4x4
Originally Posted by Racinaround View Post
Heres a Bulb Chart
Instrument-general
1445
168
194
According to that list I have the right bulb but it just isn't bright enough.
Old 03-18-2010, 01:04 AM   #6
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
I am running the cool white ones of these...
http://www.superbrightleds.com/cgi-b...Fwled-whp6.htm
And they are a just little too dim for me, so will be swapping out to these...
http://www.superbrightleds.com/cgi-b...FWLED-xHP5.htm
..because they have the forward firing driver, which the others do not...The dimmer in the headlight switch does dim them a bit as well...
Anyone who says LED's are not as bright as incandescents is a fool, LED technology over the years has come a long way and soon cars will run them for their primary headlights. I wired 1 watt Luxeon LED's in the trees at my cabin property to run off my solar/battery setup and it casts an awesome glow on the whole place.
My entire truck is LED's...Here are the tails - they are so bright they light up the concrete below them - nice improvement over the stock bulb, and the instant on light helps people stop 10 feet shorter at 60mph than incandescents.
http://www.superbrightleds.com/cgi-b...1156-x18-T.htm
Beatcoaster is offline   Reply With Quote
Old 03-18-2010, 01:19 AM   #7
spinem
haha, ford guys...
dude, im likn the purple, idgaf if i look girly. people say something, show them your "feminine" fist.
Is your reflector painted white? if so, paint it black /w/ the purples, that should give ya a little less of a "pink" look
spinem is offline   Reply With Quote
Old 03-18-2010, 01:46 AM   #8
highperf4x4
Thanks for the info!!
I'm not worried about the feedback. I don't get much grief from people. At least not usually to my face! I was wanting something closer to purple though. I'm not a fan of pink.
Yeah the reflector is painted white also. I'm just curious how the purple leds will look now.
Old 03-18-2010, 01:49 AM   #9
IndyRich
IndyRich's Avatar
So how do those led's fit into the factory bulb socket...or do you have to rewire?
IndyRich is offline   Reply With Quote
Old 03-18-2010, 01:54 AM   #10
highperf4x4
DLB
I think I understand what you meant now. A colored led bulb puts out alot more light than a filament bulb with painted glass. Not necessarily a clear one. Makes sense.
Old 03-18-2010, 04:04 AM   #11
johnechi
johnechi's Avatar
I also went with the superbrightleds and they work great! I also painted inside the gauge cluster. Whatever was that mint green colour got painted white and I got green LEDs. Needless to say, what an improvement!
johnechi is offline   Reply With Quote
Old 03-18-2010, 08:56 AM   #12
Orange
Licensed to Thrill!
Orange's Avatar
Right.
The thing with LED's is their glass is clear - so you aren't losing any light due to the coating on it. The colored incandescent's lose a lot of light when you put a coating on the outside of them.
Depending on what LED's you buy, there are plenty that are brighter when compared 1:1 with an incandescent light bulb.
Your best bet would be to go with the kind that Beatcoaster said he was going to trade out to.
For a number comparison - your standard 194 Wedge Base incandescent out out 25 lumens (per Sylvania).
If you take the 15000 mcd and 360° pattern the 5 LED lights put out, that is approximately 185 lumens.
Now, that is just a number. That isn't a pure reflection of what it will look like in your dash.
Sorry, I don't have any pics, but I have made plenty of my own LED circuits and converted vehicle interior's over to full LED.
DLB
Old 03-18-2010, 09:35 AM   #13
SATownChevy
SATownChevy's Avatar
I buy my leds from this guy and he warranties his work. I had some go out and he sent new ones as soon as i let him know. I just had to send back the old ones. Real nice guy too.
http://store.garage1217.com/insane-1...edg194168.html
They put out a lot of light. If i was going to keep my instrument panel I would go with these lights but Im going with dakota digital gauges.
Some pics of them in my car.
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 03-18-2010, 01:26 PM   #14
tubbedII
needs more $$$
tubbedII's Avatar
man satown, it looks like the helicopter is shining in your car and on your license plate!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-18-2010, 02:18 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Heres a Bulb Chart
That's some good info, thanks Rick!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-18-2010, 08:17 PM   #16
highperf4x4
Right.
DLB
Cool, but I don't have to convert anything to use the led bulbs do I? Can't I just stick them in the socket and go?
Right on!
Thanks to everyone for the input and definitely the complete bulb chart!!!
Old 03-20-2010, 03:06 PM   #17
70c10
67-72 Addict!
70c10's Avatar
highperf4x4- I used the refractor type LED bulbs I got off ebay. The socket is identical to stock 194 bulbs but these have 5 LED's in each bulb!. Here's some on ebay:http://cgi.ebay.com/ebaymotors/2-BLU...item4a9f24fadd
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-20-2010, 04:57 PM   #18
highperf4x4
Awesome Thanks!!
