Drop Springs
Ok im sure this has been asked 100 million times before, but i wanna do a 4/6 drop on my truck, is this possible to do without drop spindles in the front? i would like to get away with just drop springs. im just looking for the cheapest way to get low, cause around where i live my truck has redneck all over it and i need to get away from that lol. Also a link to a website or company what sells what im looking for would be awesome if thats not asking too much. Thanks again fella's
1991 Camaro Z28 ![]() |
BOHICA
Re: Drop Springs
CPP is a good place to look for suspension parts. If your going down 4 inches in the front, drop spindles or airbags would probably be the way to go. Just using springs you may have alignment issues. Also going that low will require shorter shocks or shock relocation front and rear. If you go down 6 in the back I think you will also need an adjustable track bar. I'm sure someone will jump in and correct me if any of my advice is incorrect. Good luck
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
![]() Join Date: Apr 2008
Re: Drop Springs
Without useing drop spindles you wount be able to get you alignment in specs.
Who needs sleep...
![]() Join Date: Aug 2009
Re: Drop Springs
I just went through something similar, my 2/4 turned out to be a 2/6
http://67-72chevytrucks.com/vboard/s...d.php?t=390511 Then ran into this thread, which was 2" lower than mine http://67-72chevytrucks.com/vboard/s...d.php?t=390476 Then cut my stock springs and wound up hard on the stops with a 5" or so drop in the front... http://67-72chevytrucks.com/vboard/s...d.php?t=392181 So I put the 2" springs back in last night till I can buy spindles. Trip |
Re: Drop Springs
im wanting to do 3/5 drop will i need to get spindels?
DJ |
Who needs sleep...
Re: Drop Springs
Some have done it, some will do it, some will tell you that you need spindles.
Personally, after putting the 2" drop springs, I'd have to think hard about it, might just shave the bump stops with 3" springs. depends on your roads ![]() The real catch there is that if you put in 3's and decide you'd rather have drop spindles, you'd need to re-purchase springs and then the spindles... Ultimately I'm going with 2" springs and 2.5" spindles up front and the 6" springs in the rear. |
Resident Lurker
Re: Drop Springs
Who needs sleep...
Re: Drop Springs
If you want it dropped 3" and buy 3" springs and then add drop spindles... it will be more than 3"
![]() If you start with the final drop, you can't drop it more and stay at the final drop, you'd drop it lower...which may be fine... the question was about dropping it 3" though. Trip |
Tot Roddin'
Re: Drop Springs
One issue with 3" springs is that when you jack the front of the truck up, the front springs have the tendency to come out to the pocket, possibly affecting your alignment.
As mentioned above... some have done it, some will, and some will not.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Resident Lurker
Re: Drop Springs
Oh, duh! Lol. I thought you were saying you couldn't use 3" springs with drop spindles at all - I forgot the OP wanted a 3" total drop. Admittedly, I was kind of freaked out because I just received drop spindles and 3" springs from CPP, but it will be awhile before I install them.
#11 | |
Who needs sleep...
Re: Drop Springs
My stock springs to 2" drop springs lowered the truck 1" so I cut two coils off the stock springs, dropping it a total of almost 6 (putting it solidly on the stops), everyone around here (locally) liked the stance (again, third link) but I want to bring it up a bit, thus the 2" springs and 2.5" spindles...maybe 3" springs later. Back to the original point before this becomes a real hijack... Knowing about the geometries involved, 2.5 spindles or 2.5" spindles and 1" springs (or 2/1) would probably be the BEST way to do it, keeping the geometries as close to stock as possible. Folks run 2" springs all over the boards with seemingly no complaints, but I haven't seen many 3" springs. Trip |
dazed and confused
Re: Drop Springs
i think i was reading some where on here that the 3" springs didnt ride real good and that they it would be better to cut the stock springs.
members met: redbaron69, billsbowtie,nc67 |
