Old 03-17-2010, 10:09 AM   #1
SOON2BLAZE
SOON2BLAZE's Avatar
2wd trailing arm crossmember?
Well I opened a can of worms when I put a 9" diff and 4" aluminum drive shaft in my blazer. The off set of the diff yolk, the 6" drop and the large drive shaft has created about a 1/2 space between the trailing arm crossmember hoop and the drive shaft ( on the top and the passanger side of the hoop) Since I was worried about having so little clearance I purchased a early classics trailing arm crossmember. It arrived yesterday and the hoop appears small. ( might need to call nate for one of his) Any one else running a non stock cross member? Should I be so concerned with the lack of clearance? Any help would be much appreciated!
SOON2BLAZE is offline   Reply With Quote
Old 03-19-2010, 09:00 PM   #2
SOON2BLAZE
SOON2BLAZE's Avatar
Re: 2wd trailing arm crossmember?
1st pic is what is there now, 2nd is whats coming from porterbuilt next week(pic stolen from nates web site) This should address any clearance issues.
Old 03-20-2010, 12:12 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: 2wd traing arm crossmember?
A miss is a miss (if youve run it through a full range of travel) clearance should be ok. Id be more concerned about the slightly cocked alignment of your driveshaft. Im running a nine inch and a 4" aluminum driveshaft but it runs straight back.
Tom Vogel is offline   Reply With Quote
Old 03-20-2010, 09:49 AM   #4
SOON2BLAZE
SOON2BLAZE's Avatar
I've read up on pinion off set and spoke to my local drive train shop. This is not an issue. If I was going to have a 9" made or fab one myself, I would center the 3rd member with the axles.
