Old 03-17-2010, 03:15 PM   #1
MalibuKasey
Artist
MalibuKasey's Avatar
Battery Drain.... !?!?!?!?!?!?
Ok this has me puzzled I got my '66.... and it runs like a top.... about a week ago I had a battery drain issue. So I figured a bad ground seeing how the previous owner had jiffy rigged a few things. So... I figured time to take a look. So I replaced the battery, cables, put an engine ground strap on, it needed a voltage regulator so I did that, had the Alternator tested too just cause its an old one(it was good). Soooo since then its been running great!!! well today at lunch I go to jump in it and..... click, click, click. I get a jump and viola runnin like a top until I shut it off.... so apparently I have some kind of parasitic drain on the battery.... any ideas?
MalibuKasey is offline   Reply With Quote
Old 03-17-2010, 03:48 PM   #2
onequickchevy
onequickchevy's Avatar
Re: Battery Drain.... !?!?!?!?!?!?
Might be as simple as a bad starter. They are cheap to replace, I would start there. Also put a voltmeter on the battery and make sure you are getting 13+ volts while running.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 03-17-2010, 04:34 PM   #3
low900rr
I had a problem like that with mine. Undo the positive cable and hook a test light between the battery post and the clamp. If theres a draw the light should go on. Go to the fuse panel and start pulling fuses til the light goes off.
My builds
69 stepside.......2wd to 4wd
http://67-72chevytrucks.com/vboard/s...d.php?t=330675
and the new 66
http://67-72chevytrucks.com/vboard/s...d.php?t=302321
low900rr is offline   Reply With Quote
Old 03-17-2010, 07:21 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
My Dad got me on this one, dirty battery posts on my old 62. They looked clean to me. You could jump start it, it would run, but it wouldn't start on it's own. He cleaned the battery posts without telling me and then smiled when i had to admit to being wrong in my diagnosis.
Old 03-18-2010, 12:37 AM   #5
daxloves
daxloves's Avatar
That is a great idea! But remember that newer stereos/CD players and clocks will draw some power so unhook them b4 testing if you have them
daxloves is offline   Reply With Quote
Old 03-18-2010, 12:45 AM   #6
67chevy2wd
67chevy2wd's Avatar
Just a thought, I had my electric choke on my carb plugged into the wrong spot on my fuse box and it was draining my battery.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-18-2010, 01:46 AM   #7
MalibuKasey
Artist
soooo.... brand new battery and cables.... so no dirt there.... no radio at all.... electric chokes not hooked up..... and I did undo the positive cable and jump it in between the positive cable and started pulling fuses and nothing happened(all of these so far are what I thought of too)..... so still no idea. Messed with it again to night and nothing...... the battery even after pulling it out was at around 11.5 volts.... sooooooooooooooo any other ideas? It has to be something stuipid..... theres not alot to these old trucks.... but this one has got me puzzled!!!
Old 03-18-2010, 02:01 AM   #8
Sillyoldman
#16876
Sillyoldman's Avatar
I'd guess a bad alternator. If its bad it can cause a reverse drain through the cable that it normally would supply. Just a guess but easy to check.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 03-18-2010, 02:09 AM   #9
Sillyoldman
#16876
I didn't see that you already had it checked when I read your post. Your battery should be around 12.55v not running, and as said it should be 13+ while running. Put a volt meter on it while its running to see if it increases. I'd have to say to start chasing wires for a short.
Old 03-18-2010, 02:12 AM   #10
67chevy2wd
67chevy2wd's Avatar
Disconnect the main power wire to the starter. Maybe the starter is bad as someone said before.
'71 GMC 3/4 ton 4x4
Old 03-18-2010, 02:44 AM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
If there is no parasitic drain, one thing I haven't seen mentioned is the battery itself. The one you replaced may have been at the end of its service life, but the new replacement could have a cell going away internally and simply won't hold a charge. Back in the 70's I had two brand new Die Hard batteries go away in this manner. If you have a similar battery in a different car you could switch, that might eliminate another possibility. I think most parts houses will also test them for free, or certainly the place that sold it should.
Old 03-18-2010, 02:48 AM   #12
daxloves
daxloves's Avatar
So if you put a fully charged battery in it stars fine, no slow turnover?
Old 03-18-2010, 09:59 AM   #13
aboz
aboz's Avatar
Had a similar problem not too long ago. The harness that runs along the driver's side inner fender panel was loose and rubbing against the clamp that is supposed to hold it. A hole was worn through brittle electrical tape (haven't rewired this baby yet) and I didn't notice it until one night after hours of trying to figure out why my new battery was draining. Because it was dark, the moment I hooked up the negative cable I thought I saw what looked a lit cigarette on the inner panel! The exposed wire was arcing against the inner fender but I never noticed it in the daytime. So my advise is...work in the dark!
ABOZ
aboz is offline   Reply With Quote
Old 03-18-2010, 10:20 AM   #14
MalibuKasey
Artist
Batterys a new interstate.... even took it back and got another one..... same prob..... the short in the wires is what I was thinking...... just need to trace everything...... and looking for it at night is prob a good idea..... Thanks everyone!!! With a fresh battery she cranks like shes new!!
Old 03-18-2010, 11:03 AM   #15
daxloves
daxloves's Avatar
After its been running and you shut it off will it start back up immediately? or does it just click even tho its been running long enough to top the battery off?
If it don't start back up I would be looking at the wires between the battery and the alternator and the plug at the alternator.
Old 03-18-2010, 12:47 PM   #16
aboz
aboz's Avatar
Had the same frickin' problem today! Traced it to the crusty old horn relay. Luckily there's Bradley Auto Parts at the entrance to my neighborhood. A true independent parts store that caters to local drag racers and car enthusiasts. The owner also owns the dragstrip in Pageland, SC.! Even if it takes the better part of the afternoon to get a part, you know damn well it's the correct part for your vehicle year. Turns out that a 63-65 horn relay is a pretty hard to find part locally but their supplier had one...and only one! I tried to replace this thing over a year ago at the Auto Zone and Advance Auto. I try to avoid the big chain stores. Huge mistake every time for a truck as old as mine.
ABOZ
Old 03-18-2010, 01:50 PM   #17
bluesfella
bluesfella's Avatar
I had this same problem a few weeks ago. Took the battery in, had it tested - bad battery. New battery went in, drove fine for a day, the next morning it was dead again.
I thought it was the voltage regulator (made a funny noise when I connected the battery cable), so that got replaced. No difference.
I also replaced the battery cables, still draining.
I un-hooked the pos. cable and put a multimeter in between, there was a drain, so I just started unplugging things one at a time until it went away. It turned out to be the alternator, even though it was less than a year old.
Using a multimeter is the only way you'll know for sure what the culprit is, unless you just started randomly replacing things like I did at first...
www.vancerutherford.com
bluesfella is offline   Reply With Quote
Old 03-26-2010, 02:55 AM   #18
MalibuKasey
Artist
So at this point im stuck....
Ive traced all the wires found a few burnt in two under the dash so I replaced those but they were just for the temp sender. I put a new horn relay on to. Just went out and checked it the battery is at 11.78 volts. So it appears the the drain is still there.... running earlier the volts were perfect.... 12.5 sitting and above 13.5 running.... so Im stumped..... I was driving it the other night and the lights started to go dim and it started cutting out.... so first thing I thought was Alt... had it tested at two different places and both of them said it was good.
Old 03-26-2010, 09:12 AM   #19
bobcostas
bobcostas's Avatar
I've had this problem, too
Havent figured it out yet. I thought (until this post) it was just a bad ground.
But for now, i just leave it on the trickle about once a week. haha
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 03-26-2010, 05:53 PM   #20
daxloves
daxloves's Avatar
If the alternator is good then once started you should be able to run the truck w/o a battery at all. So if the alternator IS really ok I still say you may have a bad wire between the alt and bat. May be almost broke and stops working after a fiew min when the wire warms up or doesnt work at all and you only runnin off the batt.
Does it stay running if you un hook the battery?
Old 03-26-2010, 10:25 PM   #21
MalibuKasey
Artist
Yep.... it stays running..... Im tracing wires now.... the last owner put HEI on it.... and moved the alternator to the passenger side.... so im going through all of it. I checked the battery 2 hours ago and it was 12.21.... couple a minutes ago it tested at 12.07
Old 03-26-2010, 10:51 PM   #22
Sillyoldman
#16876
Let the battery rest over night and check it again. Your higher readings reflect a recent charge, a suface charge. As the battery sits for a while you'll see its voltage drop which is normal. Did you have a test performed on the battery other than voltage? I seriously doubt the battery is bad, but you can also have a high voltage and a bad battery if the cranking amps read low. A volt meter wont indicate that. Maybe the battey you bought does not have the correct CA & CCA. Post the Interstate battery model number, the cranking amps and the CCA. I'll look it up for you. I would also take a good look at your grounds as stated above. Maybe add one to be sure. I had a Jeep with a bad ground. The heater sped up and the headlights got brighter when I turned left. I think it was the motor mounts making some sort of metal to metal contact. I added a ground and problem solved.
Old 03-27-2010, 11:10 AM   #23
62gmc910
62gmc910's Avatar
If you haven't solved it by now . Firmly hook a test light between the ground post of the battery and remove the cable [B]with the test light still conected[B],if the drain is from a relay curcuit it should light the test light , but if you remove the cable and then hook up the light the relay will have already released Do you have a good body to engine ground? Retest some of the things you think you are sure about and be aware that this may be an intermitant problem
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
