02-04-2003, 06:40 PM | #1 |
Shock Part #s??
OK.... so I've searched and read through 10 months worth of posts on shocks and springs etc, and I've pretty much narrowed it down to 2-3 brands, but I do have one question. Does anyone have the parts numbers or the dimensions (compressed/extended etc) for the "Shorter Shocks" I need withmy setup? I have a '72 GMC 1/2 ton w/leafs and am going to do a 2.5/4" drop using ECE drop spindles and leafs.
Thanks.... Alan |
02-04-2003, 06:52 PM | #2 |
Almost Satisfied
ECE will be able to tell yout that info when you call them to order your drop kit....in fact it should come with the correct KYB shocks.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-06-2003, 12:56 PM | #3 |
Hello ablack
I use Rancho almost exclusively. Here's a link to get there spec's. http://www.gorancho.com/documents/specifications_2.pdf hipurr72 |
