03-17-2010, 06:14 PM | #1 |
92 up dually wheels on 75-91 hubs
Does anyone know of potental problems trying to fit aftermarket 19.5 dually alloy wheels like the eagles onto a late seventies dually?
03-17-2010, 08:52 PM | #2 |
paper or plastic?
Re: 92 up dually wheels on 75-91 hubs
They will bolt right on but your very limited on tire sizes. 225/70/19.5 is the smallest you can get. IF your stock height they'll be fine. Tenessee tire and wheel can machine them down to a 19" and have more tire chioces.
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
03-18-2010, 05:27 PM | #3 |
Its a vintage COE and im after long life, LLR, smoothest ride as possible and about 33" tall.
03-22-2012, 12:35 PM | #4 |
well theres 2 reasons i didnt run aftermarket 19.5s first is i wanted to retain the classic look and second was the offset issue being i was going to lower again in the rear, i did not want a fender "too close issue" and i knew if i could locate the P-30 19.5's my offset would cause no problems.....and im glad for my build i went this route.....turned out trick and made the dually look shorter
