03-17-2010, 08:51 PM | #1 |
Redefining LowBudget
my truck is eating Power steering belts??
I have had to put 3 belts on in the last year..they all get stretched out and the steering get jumpy because the belt slips....when its jacked up it turns from stop to stop OK....and the pump is on the stock mount
looking for help...pump or sterring box??? if its the pump I'll hold out since the new motor has a pump on it thanx JEff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
03-17-2010, 08:59 PM | #2 |
Re: my truck is eating Power steering belts??
Possibly worn pulley or misaligned pulleys.
03-17-2010, 09:02 PM | #3 |
knuckle buster..
X2! Its most likely the pulleys not the pump.
Get out your straight edge and check your alignment from pulley to pulley. good luck!
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) join the the smilies fight club |
03-17-2010, 09:07 PM | #4 |
nope not that easy....stock mounts and pullies
03-17-2010, 09:14 PM | #5 |
sounds like alignment issues, is your belt too wide for the pulleys? try running the engine and watching to see if anything is bent, or if your pump is moving.
03-17-2010, 09:16 PM | #6 |
what they said
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
03-17-2010, 09:19 PM | #7 |
using cheap belts???
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
03-17-2010, 09:38 PM | #8 |
Sierra Grande Club
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-17-2010, 09:45 PM | #9 |
ok guys these are all great ideas BUT
the pump is tight, things are lined, up not bent, and I have been running a NAPA gold belt, seems to be the right width too.. this is why I kinda stumped...
03-17-2010, 09:53 PM | #10 |
Moderator
You need a new pulley, that's my guess. When replacing use the proper tool to pull and install it, or the new one will wobble too. Watch it while the truck is running. If there is any wobble to it, there is your problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 03-17-2010 at 09:55 PM. |
