Old 03-17-2010, 09:23 PM   #1
bigblocksean
67 4x4 frame swap
Greetings guys, I have a question regarding a frame swap..here goes. I have a 1967 snb and have been searching for a 67-72 4x4 frame and running gear..no such luck. My question is I have found a complete 1974 1/2 ton frame and running gear, will the 67 cab, front clip, and bed drop right on? are the frames the same? any help would be greatly appreciated.
bigblocksean is offline   Reply With Quote
Old 03-17-2010, 10:05 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 67 4x4 frame swap
Welcome Sean, noticed you were in Kansas too. No, they won't directly drop on. You will have to reuse the old mounts for the body and I believe make new ones for the bed. Go to the 4x4 section of this site and do a search, it comes up pretty often over there. Good luck Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-17-2010, 10:06 PM   #3
msgross
msgross's Avatar
build your 2WD into a 4WD
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-18-2010, 06:52 PM   #4
bigblocksean
Hey thanks for the info Trevor, believe it or not I found a 72 shortwide 4x4 project truck for cheap today. Now I get to drag yet another truck home lol.
Old 03-18-2010, 07:28 PM   #5
msgross
msgross's Avatar
that works, good year too... disc brakes, power steering
The Garage:
Old 03-18-2010, 08:14 PM   #6
gkesseru
gkesseru's Avatar
The 74 has a drop in the frame under the cab so making it fit will be really hard (except for a 4X4 you could put 3" lift kit on front engine mounts to make up the difference). Also the rear mounts are inboard on the later truck vice outboard on the earlier one. The bed mounts on 67-72 are 3" higher than the rear cab mounts while the later frame is straight back.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 03-26-2010, 06:39 PM   #7
flips72
flips72's Avatar
wish you were closer to tn. ihave a restored 72 short 4x4 frame, with new 4 inch lift (no blocks),new brakes front to rear,new brake lines, disc brakes power steering, tie rods,pitman arm, and the list goes on. just lost intrest, well actually 65 took over. it needs a new home.
flips72 is offline   Reply With Quote
Old 05-30-2010, 02:16 PM   #8
tgpeden
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
tgpeden is offline   Reply With Quote
Old 05-30-2010, 09:17 PM   #9
flips72
flips72's Avatar
sorry its gone
