![]() ![]() ![]() I Have A 1965 Chevy C-20 283 With A 2BBL Rochester Carb On It OK My Problem Is When I Give It Fuel It Bogs And Wont Start It Started When I Cleaned My Old School In-Line Glass Fuel Filter Then It All Began... I Cleaned The Carb Out Clean And Cleaned The Fuel Tank And Blew Out The Fuel Lines Now Has New Clean Fuel... Now It Dont Work So If Any One Know's Whats Going On Help Me Please... lostechos13@yahoo.com Louie Aka MR.Pain... |
#16876
Re: Truck Keeps Dieing
I'd look at the fuel pump. Vacuum leaks. Maybe a stuck needle valve. Are you priming the carb when it starts and then dies?
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
Yeah When I First Start It We Prime I'll Check The Fuel Pump In The Morning... The Needle Valve Never Thought If The But Even If The Carb Is Getting Fuel Could If Be The Pump Still I Can See Fuel In The Line...
Senior Enthusiast
If this just started out of the blue, I'd say look at the accelerator pump. But since it started after you cleaned everything, it's gotta be some crud was dislodged and is plugging something up. I'd start with the fuel filter, and see if it is newly plugged up. If not, I'd pull the carb apart again, and after cleaning all the passages with carb cleaner, make sure to blow them all out with compressed air to insure any blockages are cleared. Just make sure all the springs and check balls are out first so they don't go flying into neverland.
I've Checked The Accelerator Pump And It Seams To Be Working But I'll Check It Again I Put The Carb Filter Back On And Took Off The In-Line One It Was Dirty And Now Cleaned But It Wasn't Filtering Before It Was Loose And Bouncing Around Doing Nothing...
Member of the longbed union.
Welcome to the site first of all. did you adjust the carb at all. Maybe your giving too much fuel. Were your plugs bad before. I had the same problem with my truck. Carb had junk it in and caused the floats to stay too high. Fouled the plugs out. Clean your plugs really good and try to start again. If it does adjust the carb and clean the plugs good.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 03-17-2010 at 10:34 PM. |
http://i535.photobucket.com/albums/e...0224101808.jpg
<a href="http://s535.photobucket.com/albums/ee355/babyguts87/?action=view¤t=0224101808.jpg" target="_blank"><img src="http://i535.photobucket.com/albums/ee355/babyguts87/0224101808.jpg" border="0" alt="Photobucket"></a> |
Yeah Me And A Buddy Tryed To Adjust The Air/Fuel Mixture But Still Did The Same Thing And The Float Seams Ok But I'll Check Again The Fuel Inlets Were Pluged Before And After Soaking Then In Carb Cleaner Over Night The Truck Ran Fine But Now They Work And IM Lost On What To Do..
Nothing Like The Smell Like Rust In The Morning...
do those have power valves on them. Could have blown it if it backfires.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
