Old 03-17-2010, 11:49 PM   #1
sider68
sider68's Avatar
Shifter Options
I have a 56 chev auto (350 turbo) It has a BM quik shifter in it. Great for going in a straight line. I would like to replace it with something more user friendly. Is there something from a wrecker that would work or should i be looking at Lokar or Hurst? Please advise
sider68 is offline   Reply With Quote
Old 03-18-2010, 12:29 AM   #2
rjs53
Re: Shifter Options
are you going to put any kind of console in it? would almost have to. what about a neon or saturn. I put one in my chevelle from a 98 camaro they work nice but needed a console
rjs53 is offline   Reply With Quote
Old 03-18-2010, 02:36 AM   #3
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Re: Shifter Options
I have a 7oor4 in my 55 and I'm going to run this Lokar Shifter. Probably the best one I've found. I'm getting mine tall (22") but they make a smaller and a taller one. It's push button on the top. A little pricey though at $270
kalirodding is offline   Reply With Quote
Old 03-18-2010, 08:25 AM   #4
sider68
sider68's Avatar
Re: Shifter Options
No Console in mine Im putting a bench seat in it as I have two kids so i need a lower profile otherwise Id do what you are doing. Nice unit
Old 03-18-2010, 10:27 AM   #5
1952ssr
1952ssr's Avatar
Re: Shifter Options
I've been looking into the Gennie shifters for the '52 /4L60. I found them at hotrodexpress.com for 200 bucks. I like the way they select the gears better than the push botton Lokar.
1952ssr is offline   Reply With Quote
Old 03-18-2010, 12:05 PM   #6
BlueJeep
BlueJeep's Avatar
Re: Shifter Options
I have the same need for hauling 2 kids in car seats in my 49, so I went with an auto s10 column, and will use Lokar's shifter linkage to hook that up to my 4L60. I thought I would modify the original cable shifter...but for $50 I think the Lokar linkage is hard to beat.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-18-2010, 03:35 PM   #7
blitz'd
vintage car junkie
blitz'd's Avatar
Re: Shifter Options
I have a locar and im not very happy with it. The button sticks at times and you have to push it between odd gears.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 03-19-2010, 03:45 AM   #8
kalirodding
CLASSIX Truck Club
Re: Shifter Options
Thats too bad. My friend has it and has never had one problem with it. Sounds like you bought a lemon.
Old 03-19-2010, 07:50 AM   #9
2ndGenRR
2ndGenRR's Avatar
Re: Shifter Options
I had a Lokar in my '62, so maybe it was the 500+hp, but that push button would rattle like crazy going down the road, which drove me crazy. Had to drive around holding the shifter with my thumb on the button just so it wouldn't rattle. Went with a Gennie in the '48...I really like the way it gates through the gears much like a column shifter and NO button.
Anyway, just something to consider. Although it sounds like with the need to haul 2 kids around converting to a column shifter would be the way to go though...
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 03-19-2010, 01:54 PM   #10
OrrieG
OrrieG's Avatar
Re: Shifter Options
My build thread shows what I did. column shift with 350TH. I used a B&M cable and lower brackets and fabbed one for the firewall. Make sure the level pivot dim is the same on the trans and column. Before I had a floor shifter but it got old having the kids in the middle of the seat kicking it out of gear and fighting their feet.
here is link to mine http://67-72chevytrucks.com/vboard/s...&postcount=134
OrrieG is offline   Reply With Quote
Old 03-19-2010, 08:33 PM   #11
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Shifter Options
I've got the lokar in mine and it works great. I'm running a bench seat and am changing the shifter to a double bend one so it gives the middle person a bit more room.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-19-2010, 09:00 PM   #12
Gene Sharp
Re: Shifter Options
My 53 has a 700R4
It also has a tilt column out of some sortof GM car or pikup
maybe the 86 Blazer that donated the chasis
all the origional linkage is hooked up and it works perfectly
so why not go with a shift column ?
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 03-20-2010, 12:31 PM   #13
blitz'd
vintage car junkie
blitz'd's Avatar
Re: Shifter Options
That is the one I have, love the shape of it. I bought a new knob for mine yesterday, maybe it wont stick so much.
Old 03-20-2010, 05:30 PM   #14
entourageguy
Yellow truck club
Re: Shifter Options
I'm trying to think since I haven't driven my truck for 4 plus months.
Should have to push button to get out of neutral
going from neutral to reverse
maybe OD to 3rd.
Hmmm time to go out to the garage....
Which knob did you have that was giving you trouble? I know my 8 ball had a bit of stickyness to it but I really found once it was adjusted and set up it worked great on my 700R.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-22-2010, 08:47 AM   #15
blitz'd
vintage car junkie
blitz'd's Avatar
Re: Shifter Options
maybe OD to 3rd.
If I remember right I think you have to push the button from drive to neutral also. I think that is what drove me nuts. I had the brushed alloy, bought the plain black knob.
