Old 03-18-2010, 02:04 AM   #1
GMC Guy
GMC Guy's Avatar
clunking sound under hood....
yesterday i noticed a "clunking" sound when stopped at a light. i was coming back from a friend's house a few miles away. and out on a long open road i was happily cruising at around 70. engine temp was good, oil pressure good. got into town and when i stopped at a light i heard a intermittent clunking noise...
i pulled over, got out and looked, but didn't see any obvious causes. i did find it weird that it was only making the sound when i stopped completely or put it in park. but not when driving down the road.
so i began thinking...water pump? balancer? fan?
i'm really at loss here guys, need some advice...
*seems to be making noise after high speed driving/hard acceleration, then coming to stop (noticed that tonight)
**also, no noticeable loss in power.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 03-18-2010, 02:24 AM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: clunking sound under hood....
Clunk or clatter? My first thought if its clatter would be a nut backed off a rocker stud.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 03-18-2010, 02:50 AM   #3
Stepsideride
how do your motor mounts look?
Stepsideride is offline   Reply With Quote
Old 03-18-2010, 03:10 AM   #4
GMC Guy
GMC Guy's Avatar
1. i'll check under the valve covers tomorrow
2. motor mounts are probably original, motor was replaced in 1996 (well before i owned it), they look pretty old so i doubt they replaced them
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-18-2010, 07:53 AM   #5
Turbo85GMC
Turbo85GMC's Avatar
Does it clunk from Fwd to Rev and back again? Check out the u-joints as well.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 03-18-2010, 12:29 PM   #6
GMC Guy
GMC Guy's Avatar
i haven't noticed it making noise in reverse. but it's doing it all the time either
what should i check for with the u-joints?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-18-2010, 12:38 PM   #7
slipkorn34
slipkorn34's Avatar
mines doin the same thing only itll only do it a few times a week, and completely at randomill check the rockers too since my valve cover gaskets started leaking anyway
1969 mercury cougar XR-7 - sold
1978 Chevy C-10 Scottsdale - sold
1996 chevy k1500 - sold
1970 mercury monterey - sold
1971 chevy c10 4 speed 4x4 - dd
slipkorn34 is offline   Reply With Quote
Old 03-18-2010, 12:59 PM   #8
GMC Guy
GMC Guy's Avatar
does it only do it when you're stopped?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-18-2010, 01:01 PM   #9
jchav62
1962 C-10
jchav62's Avatar
Since you say you are losing power, my guess would be something in the valve train.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-18-2010, 01:16 PM   #10
GMC Guy
GMC Guy's Avatar
my bad, i'm not really losing any power. and i don't hear anything abnormal under acceleration. only when coming to a stop
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-18-2010, 04:21 PM   #11
jchav62
1962 C-10
jchav62's Avatar
Make sure the torque converter is tight. I had one come loose on me one time and it made a 'knocking' sound.
Joseph Chavez
Old 03-18-2010, 05:20 PM   #12
GMC Guy
GMC Guy's Avatar
can i tighten the torque conv. with it in the truck?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-18-2010, 07:01 PM   #13
Stepsideride
yes you can its only three bolts.
Old 03-18-2010, 07:19 PM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
x2 That's what I was wondering or maybe bad u-joints as well.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-18-2010, 07:40 PM   #15
GMC Guy
GMC Guy's Avatar
the truck was making the noise again today, luckily it did it long enough so i was able to look under it to see where the clanking was coming from......turns out an exhuast pipe hanger worked itself loose and the pipe coming off the driver side header was banging up against the tranny crossmember
thanks for all the advice, fortunately this time the problem was something stupid.
Greg
1974 GMC
L33 5.3/4l65e
.................__
