Old 03-18-2010, 10:09 AM   #1
michael bustamante
michael bustamante's Avatar
700r4 tranny install question
I just installed a 700r4 in the 67 longbed and Im using my stock auto tranny crossmember.
Heres the question. For you guys running this tranny, did you hve to drill new mounting holes in the frame to bolt down the crossmember or am I doing something wrong here? I thought the turbo 350 long tailshaft (which is what I was running) and the 700r4 basically used the same trans housing
1967custom
michael bustamante is offline   Reply With Quote
Old 03-18-2010, 10:40 AM   #2
AusTx68
AusTx68's Avatar
Re: 700r4 tranny install question
I swapped from a 396 w/400 tranny to a 383 w/700r4. I bolted it up without making any holes in the frame.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 03-18-2010, 10:55 AM   #3
michael bustamante
im running a 350 hei, mount towers mounted in the front holes. the turbo 350 tranny put the crossmember in the usual location but now that I bolted up the 700r4 it seems to have scootched it back
1967custom
Old 03-18-2010, 11:28 AM   #4
425HP409
425hp409
425HP409's Avatar
The 700R4 trans mount is further to the rear than the 350, so just scoot the crossmember back and drill new holes in the frame.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 03-18-2010, 12:16 PM   #5
SATownChevy
SATownChevy's Avatar
thats what i had to do.
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 03-18-2010, 12:28 PM   #6
splatrd
From what I understand, the 700r4 is 3" longer than the TH350. I installed one in my El Camino which originally had a TH350 and I had to move cross member back and shorten the drive shaft by 3".
1972 Cheyenne C10 LWB
1970 C10 292 I6 3 speed
2017 Silverado LS 4x4
1978 El Camino SS, LT1 swap
2016 Camaro SS
splatrd is offline   Reply With Quote
Old 03-18-2010, 02:33 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There are three different lengths of TH350 transmissions, 6 inch, 9 inch, and 12 inch. The 700 is the same length as the 9 inch unit so no drivesahft mods needed if swapping them.
But, like said above regardless of the length, the 700 mount is further rearward and does require new holes drilled.
Old 03-18-2010, 04:50 PM   #8
michael bustamante
thats what I needed to know Guys. thank you. I gues Ill have to drill more holes in the frame
1967custom
