Old 03-18-2010, 02:13 PM   #1
Rat Bastid
Rat Bastid's Avatar
proper way to replace doors
hey guys,im replaceing 2 doors and am wondering if replaceing the hinges are gonna make fitment impossible? seems my new hhinges are thicker than original and are causeing contact with rocker in front and contact at radius at top rear,any help here would be appreciated as my rage is building.............
Rat Bastid is offline   Reply With Quote
Old 03-18-2010, 02:17 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: proper way to replace doors
Remove the striker from the cab. Adjust the doors as needed
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-18-2010, 03:20 PM   #3
lks dcvn
lks dcvn's Avatar
on removing the striker plate in the b pillar I am doing this now on my Blazer build.
lks dcvn is offline   Reply With Quote
Old 03-18-2010, 03:33 PM   #4
GruntMoanCough
GruntMoanCough's Avatar
Pics would help, but it sounds as though your door needs to be lifted at the hinges.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 03-18-2010, 06:17 PM   #5
jcblue
jcblue's Avatar
just put new pins in your original hinges
jcblue is offline   Reply With Quote
Old 03-19-2010, 01:21 PM   #6
Rat Bastid
Rat Bastid's Avatar
repinned and bushed lower original hinge,put back on original top hinge and still it is hitting will get photos up later,frustrating for sure
Ron i think you are on too something it does need to lift some,maybe reem out the holes on hinge a bit allowing more movement for adjustment?
Old 03-19-2010, 01:40 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
There are 2 companies that reproduce the door hinges for our trucks. One company makes them thicker than the other. You evidently have the thicker hinge. You can grind the head of the bolts to allow clearence or just repin the originals. We use to get the reproductions that we the thinner ones, but for some reasone our suppliers now have the thicker ones. I am on the search for the correct ones once again. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-19-2010, 01:57 PM   #8
GruntMoanCough
Far as I understand, you are using the original hinges (with the lower one being repinned), you have removed them and have replaced them.
There should be some adjustment (up/down) and it is quite common to reinstall the hinges and/or door lower than they were before.
Try loosening off the bolts and sliding the door up to give you rocker clearance, keep one of the hinges tight at the door and jamb while you are adjusting the door, to keep it from dropping again.
