69 LWB rolling Chassis?
Can 60-66 Chevys use a 69 LWB chassis, or are the rad, cab, and bed mounts different? Is the wheelbase different?
Thanx Dano
![]() ![]() It ain't yours, if you didn't build it! |
Re: 69 LWB rolling Chassis?
Radiator & rear cab mounts are different. The bed mounts are similar but the holes on the later frames are slotted for more adjustment.
The front frame horns are also different... the bumpers will not interchange.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
