Retired from a track near you!
![]() Join Date: Feb 2010
72 lwb single exhaust
Who sells an exhaust for lwb with coil springs? Looking for single, that can be bolted on, removed, ceramic coated, then re-installed. Any leads would be greatly appreciated ! Thanks
Re: 72 lwb single exhaust
I would think that it would be cheaper to have an exhaust made up locally and ship it off to have it coated.
I just had a quote done for my 72 rebuild, a single exhaust, and it was 340 to 360 depending on the tip I choose. That's from the ramhorns back. |
Autozone shows parts available
http://www.autozone.com/autozone/cat...&parentId=61-0 Walker is a manufacturer , may be sold by a local parts stores http://www.walkerexhaust.com/catalog...crnexhaust.asp You may also check NAPA or other parts stores local to you
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab Last edited by Chevydude56; 03-18-2010 at 10:08 PM. |
#4 | |
I dont want the muffler shop welding on the frame, etc. I would have to be standing there with it, so I'd rather do it myself. It's that kind of build. I have a shop locally to coat the exhaust, so that's not an issue. Thanks for the input for sure! |
#5 | |
Called my semi-local Napa, he had no listing at all. I'll find a Autozone for sure, maybe they will have something! O'Reilly has a "Y" pipe, no coil spring tail pipe. I may piece together a system...Thank you very much ! |
I would rather install mine also.
I am suprised Walker said they didn't have anything. If you follow the walker link you can look it up , it shows all the part #s except a muffler for coil springs? Here is also a link to Advanced auto parts, with Walker part #s http://shop.advanceautoparts.com/web...t*Exhaust+Pipe Good luck
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
the main part of the exhaust system you need is the y pipe // i got one from carquest about 6years ago dont know if still available??
have you checked LMC catalogue the used to have the original single exhaust sending out to get ceramic coated can cause fitment problems where the pipes slip together
#8 | |
O'Reilly has the Y pipe. I am going to swell each of the joints a little before having it coated, maybe that will work...Thanks a bunch! |
