03-18-2010, 07:36 PM | #1 |
SWB 4x4 Collector
Nice day for some pics
Hey guys, finally finished color sanding the paint on the truck. So for now, it is finished. It was a wonderful day, so I decided to take some pics. Trevor
Here's what we started with about this time last year.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
03-18-2010, 08:00 PM | #2 |
The One And Only !!!
Re: Nice day for some pics
Looks much much better Trevor, Awesome job dude !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
03-18-2010, 08:22 PM | #3 |
SWB 4x4 Collector
Much appreciated Rob. Trevor
03-18-2010, 08:27 PM | #4 |
Location: Where I come from, it's cornbread and chicken...
that looks great man...one question...did you buy the aluminum overlay on the gauge bezel from a company online, or did you get a NOS bezel...that thing looks really good
03-18-2010, 09:19 PM | #5 |
SWB 4x4 Collector
Actually, I restored the inside trim by a couple of ways.
The instrument panel had some white spots on it like most do and when trying to clean it, it rubbed off the aluminum look. So I just used some Steel Wool and some soap on the overlay and it took it down to the white plastic. I then pryed off the instrument faux aluminum overlay from the bezel. Once it was cleaned off, I sprayed black plastic paint over the white plastic overlay, and then airbrushed Alclad Chrome paint over the black paint. Then I once again used Steel Wool rubbed in a straight path to recreate the look of the brushed aluminum. For the door aluminum trim, I used wd40 and an old credit card (going slow) and was able to peel off the trim. From there, I sanded it smooth and then used like 220 grit in a one way motion to recreate the brushed look and Clearcoated them. Then reattached them with contact cement. Trevor
03-18-2010, 09:24 PM | #6 | |
03-18-2010, 09:28 PM | #7 |
It followed me home?
Looks great!! Nice work on the dash inlay
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-18-2010, 09:30 PM | #8 |
SWB 4x4 Collector
I don't think you can get alclad in rattle can. You can get spaz-stix chrome rattle can that is actually a little more chrome looking to me. Airbrushing alclad in mist coats over black can get you really close to Sterling silver/polished aluminum looking results. I got mine from a hobby store a year or so ago when I was up at college. You can find it online though for a lot cheaper, or like I said, look up spaz stix. Trevor
03-18-2010, 09:34 PM | #9 |
thanks again man...I'll be looking for it...I'm going to be restoring the little things like this in my interior very soon...this just puts more things on the list...
03-18-2010, 09:43 PM | #10 |
SWB 4x4 Collector
For the instrument panel overlay.... word of caution... just take your time. I just used an old credit card and stuck the bezel under warm running water in our shower. I would just shimmy the credit card under the overlay very slowly, to break loose the contact cement. Just use extreme caution around the hvac control cutouts. Trevor
03-18-2010, 09:44 PM | #11 |
once again thanks for the tips...anymore...lol
03-18-2010, 10:01 PM | #12 |
SWB 4x4 Collector
Umm, haha....
a good way to fix any broken aluminum door trim pieces that have broken tabs in the back that attach to the door panel... . . use the credit card routine with wd40, which really takes some time and makes your fingers sore, but saves you a lot of money. Once you get the aluminum piece off of the plastic. You can take the plastic molding off of the door panel and drill out a hole centered where the old broken tab was. Use a counter sink bit and counter sink the hole just enough for a flat headed bolt to sit flush with the plastic that the aluminum will rest on. Put the molding back onto the door panel, and get it sitting where you want it. Then apply contact cement to both the plastic and the back side of the aluminum piece (after they have both been cleaned of course of old contact cement) and really cover the head up good with contact cement so it stays put. If your aluminum trim got a little bent up taking it off, you can bend it and sand it back smooth, and then do the trick I talked about earlier on it. Let both pieces air dry for about 30 min. - 45 min. then line up and stick together= permanent fix that looks good and saves money and parts. Trevor
03-18-2010, 11:22 PM | #13 |
STOLEN
Great looking truck. Thanks for taking the time to share some pics.
In Search Of |
03-18-2010, 11:56 PM | #14 |
once again another great tip...thanks alot man
03-19-2010, 12:13 AM | #15 |
Nice Beffy TRUCK BRO...
1979 GMC Sierra 15 1986 Danco Rollback 454 4spd 1986 Jerr-Dan Rollback 454 4spd 1978 GMC Jerr-Dan 454 Tonawanda 4spd FOR SALE 85 Chevy Wrecker 454 4spd AATAC Always a Friend...Michael |
03-19-2010, 01:46 AM | #16 |
AWESOME Trevor!!!! Makes me want to finish my 1 Ton.
I would like to see your Chevelle. |
03-19-2010, 09:58 AM | #17 |
SWB 4x4 Collector
Hey Patriot, my cpu's hard drive crashed awhile back where I had some pics of it, and it's down at a local shop getting tuned up. Here is a pic of it from down at the shop waiting it's turn over winter. Trevor
03-19-2010, 10:09 AM | #18 |
