03-18-2010, 08:16 PM | #1 |
t5 troubles...?
Just got done finishing up the t5 swap, and strange thing, clutch is burning a little and it wont shift into first gear. i know we put the clutch in the right way, transmission was just recently rebuilt by a local transmission shop, not sure of what it could be at this point. any thoughts?
marshall
70 Chevy C10, LT1, T5, "Blue Beast" |
03-18-2010, 08:38 PM | #2 |
Re: t5 troubles...?
ttt..
03-18-2010, 08:51 PM | #3 |
Re: t5 troubles...?
Not enough play in the linkage? Um......?
03-18-2010, 09:27 PM | #4 |
Re: t5 troubles...?
could be. when we did this, i was told i didnt need to change the pressure plate, that the pressure plate for the 3 spd saginaw would work, could it be the pressure plate needs changing?
03-18-2010, 10:08 PM | #5 |
Re: t5 troubles...?
Will it go into 1st with the truck turned off?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-18-2010, 10:15 PM | #6 |
Re: t5 troubles...?
actually it did...it went into all the gears when the truck was off...
03-18-2010, 10:58 PM | #7 |
Re: t5 troubles...?
With the truck running, does the trans not shift into 1st and or grind? If you answer yes, than the clutch is either not releasing fully, or the clutch disc could be hanging up on the input shaft. There also exists the possiblity that you have or were given the incorrect clutch disc. I would remove the metal flywheel cover and with the aid of a friend, have them push the clutch pedal down while you look to see if the gap between the pressure plate/clutch disc/flywheel opens up. It will not move a bunch but you should be able to see it.
Good Luck, MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
03-18-2010, 11:04 PM | #8 |
Junior Member
Re: t5 troubles...?
had a similar issue with a new clutch in a scout. ended up turning the vehicle off...put it in gear and hold clutch pedal in all the way,then start it. with foot on brake and clutch,it broke free and was great ever after.
67-72 Truckless for the moment Member# 1126 The one that got away http://customclassictrucks.com/featu...001/index.html |
03-18-2010, 11:08 PM | #9 |
Re: t5 troubles...?
you need to shim it away from the bell housing to get the input splines out of the pilot bearing
03-18-2010, 11:11 PM | #10 |
Re: t5 troubles...?
I can't get it to go into first at all. But in the other gears yes there is grinding. I think it's the right clutch disk but I will double check.
03-18-2010, 11:14 PM | #11 |
Re: t5 troubles...?
The noise it's making is kind of similar to what sounds like a fizzing sound when you try to put it in gear. Not sure if this helps
03-18-2010, 11:17 PM | #12 |
Re: t5 troubles...?
had the same problem put in a couple of washers to test and it fixed it there is a adapter o make up the difference
03-18-2010, 11:18 PM | #13 |
Re: t5 troubles...?
What do you mean? Washers at the transmission mount bolts between the bellhousing and trans?
70 Chevy C10, LT1, T5, "Blue Beast" Last edited by aggieguy713; 03-18-2010 at 11:19 PM. |
03-18-2010, 11:18 PM | #14 |
Re: t5 troubles...?
03-18-2010, 11:21 PM | #15 |
Re: t5 troubles...?
the input is to long on the t5 so space it out put a shim betwine the trans and bell housing 2 washers would work on mine
03-18-2010, 11:30 PM | #16 |
Re: t5 troubles...?
The transmission shop that rebuilt it for us said they cutthe shaft to the Right length. Does it still need the spacer
03-18-2010, 11:39 PM | #17 |
Re: t5 troubles...?
did they cut the splines or the shaft the trowout bearing rides on
a easy check is to losen the trans and put something between to space it out about a 1/4 inch and test it that way you dont take it all the way out for nothing that how i figued it out i also had to drive the plot bearing all the way in Last edited by angry; 03-18-2010 at 11:43 PM. Reason: more info |
03-18-2010, 11:42 PM | #18 |
Re: t5 troubles...?
Ok. I think both, but I'm not sure to be honest with you. I will try that. Would that cause the clutch to burn and smell? Sounded like it wasn't engaging/disengaging to me
03-18-2010, 11:47 PM | #19 |
Re: t5 troubles...?
for mine the input keep the disc spining even with the clutch in so it smelt burnt and wouldnt shift in to first will running and would not shift with out grinding
03-18-2010, 11:49 PM | #20 |
Re: t5 troubles...?
thats the same stuff i went trough for a day or two i tryed the shim and it worked ike magic
03-19-2010, 12:00 AM | #21 | |
The Older Generation
Re: t5 troubles...?
If the shop cut the end of the pilot shaft off 9/16" "and" turned the splined area back 9/16" that shouldn't be your problem. If they didn't, that's another story..... The spacer from Hamilton is 9/16" thick. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-19-2010 at 12:00 AM. |
03-19-2010, 12:10 AM | #22 |
Re: t5 troubles...?
Ok. Well the shop told us it was cut and ready to go. I still think it's something to do with the clutch, just not sure what
03-19-2010, 12:18 AM | #23 |
Re: t5 troubles...?
My T5 is out of an 89 camaro and I have it behind a 454. I have no spacers, the input shaft hasn't been changed and no problems. And here is the clutch I have...
Clutch Do you have the correct throwout bearing? Sounds like whatever it is, the clutch is staying engaged. I agree with ratpackv8sonly and start with linkage and then go from there. Not sure if any of that helps you though...good luck and let us know what the fix is when you find it.
'67 C-10 Shorty - 454, 5spd, and speed holes! |
03-19-2010, 12:26 PM | #24 |
Out of the carpool lane.
Re: t5 troubles...?
You should use the clutch disc from whatever year and model T-5 you have. If yours came out of a 88 Camaro than use an 88 Camaro clutch.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
03-19-2010, 01:41 PM | #25 |
Re: t5 troubles...?
Is it hydraulic clutch or mechanical?
