03-18-2010, 08:16 PM | #1 |
Redefining LowBudget
need BRAKE help fast!!
ok heres a pic of what I have my truck has crap for breaks.....I have 2 thoughts
is my proptioning valve in correctly are my brake lines crossed my truck is a 70 drum drum truck what happen is my line that cross's the X memember got a crack it drained the back of the master so I'm not sure whats going on ....I have pulled allt he drums and pads and drums are new I need to attack this in the morning I need my truck tomorrow afternoon Thanx Jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
03-18-2010, 08:18 PM | #2 |
Re: need BRAKE help fast!!
I have been looking at some other pics of brake set ups and it seem like most of the pics I see the wire for the light is on the top??
03-18-2010, 08:55 PM | #3 |
Chevy Lover Till The End.
Here is my old setup and it worked great untill the booster went bad. My light wire plugs in the bottom. Hope this helps you.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
03-18-2010, 08:59 PM | #4 |
Its a Truck Thing......
can you get all the drums to bleed? If so make sure the rear brakes are properly adjusted, If you can pull the drum off the back with little force, you may need new adjusters, the back should have some drag to it.
If you cant get the front (or the one that bled back to the master) to bleed you may have to bench bleed the master to get the air out of it. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
03-18-2010, 09:03 PM | #5 |
hey camaro nut your set up looks like mine but I think my proportioning vavle is backwards??? and which line goes to the rear......????
03-18-2010, 09:21 PM | #6 |
smitty everything is new or cleaned..bleeding isn't an issue....I'm just not sure things are routed in the right directions??
03-18-2010, 09:27 PM | #7 |
Were the brakes OK until the line leaked?
You need to replace/repair the line and bleed all the brakes. Any air in the system will give you bad brakes. You don't have a proportioning valve , you have a distribution block.
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
03-18-2010, 09:32 PM | #8 |
the brake where...ok....I was never impressed with them ..I just added the booster set up and they didn't seem any better..I was thinking the booster is bad....
what I am sure of it that all the lines are new bleeding isn't an issue pad and drums are new and no leaks at the wheel cylinders Last edited by Hottrucks; 03-18-2010 at 09:33 PM. |
03-18-2010, 10:50 PM | #9 |
Grandpa in the rustmobile...
your 'block' 'valve' etc is upside down compared to my disc setup......
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-19-2010, 12:42 AM | #10 | |
Here is a picture of mine , I think the booster was added at some point. second picture , closeup of distribution block, switch on bottom Third pic is a drum brake without a booster, switch on bottom Forth picture is disc brake truck with prop valve, switch on top.
03-19-2010, 02:01 AM | #11 |
67-72 parts collector,…
Your distibution block is backwards.
In your pic the back of the block needs to face the front of the truck. Both front lines are towards the front of the truck. (front bowl of M/C and front brake lines) Both rear lines are towards the rear of the truck. (rear bowl of M/C and rear brake lines)
03-19-2010, 07:00 AM | #12 |
well I'm going to flip the block around and blead the lines again....Disc brakes are only a few months away then I'll be looking for a disc vavle
I'll keep you posted
03-19-2010, 07:10 AM | #13 |
on ym 71 the block vavkle is turned witht eh wire going up
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-19-2010, 07:39 AM | #14 |
I saw somewhere, on Speed TV or something, that when you put in a booster you need to change the pedal and rod. Something about a different size rod needed to operate the booster properly. If you didn't change that out when you added the booster, that might be why you don't get the full power from them.
www.coolmoodart.com |
03-19-2010, 07:58 AM | #15 |
did the swap it was very easy..I swapped every thing including the rod....I'll be done in a coule hours and see what happens
03-19-2010, 08:05 AM | #16 |
Size Matters
Is your concern that a front line was leaking and the rear resevoir was the one that went dry? That is normal I think. You get more pressure on the front that way.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! Last edited by Longhorn321; 03-19-2010 at 08:05 AM. |
03-19-2010, 08:26 AM | #17 |
Yep and that the "valve" /"block" is in correctly...I want more presure to tthe front it makefor better wheel stands!!!!
03-19-2010, 08:45 AM | #18 |
Size Matters
Here is a pic of my '69 C20 Longhorn with Drum/Drum. It looks exactly like yours.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
03-19-2010, 08:56 AM | #19 |
Between Trucks...
If your master cylinder went dry you might need to bleed it again. You can do this on the truck, just unhook the lines and hook up the bleeding kit. Might want to tape or lightly clamp the bleed kit lines so they don't fall out of the reservoirs.
Beat it to fit, Paint it to match... |
03-19-2010, 09:05 AM | #20 | |
03-19-2010, 09:15 AM | #21 |
I have a `70 drum n drum setup that I'm changing to front disc. My wire is on the bottom of the prop valve and since it was a 1 owner truck I believe that is how mine came from the factory.
03-20-2010, 06:31 PM | #22 |
ok I blead everying out did some swapping and I think that they are as good as they are going to get I bought a use Booster from a board memeber and I'm pretty sure its FUBAR...but I will say they are 50% better and I think one more bleeding will help a tad more..
than Guys for the pics it helped alot..mine now looks like long horns and chevy dudes I believe that to bet he correct set up |
03-20-2010, 10:08 PM | #23 |
distribution block is backwards fix that and you should have better brakes.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
03-21-2010, 05:57 PM | #24 |
I would agree. If you check your photo with Camaro-Nut's, the dist.block should have the mount bolt at the back. My '69 BB Chevy was the same.
RW (Photo coming) Last edited by 69BB396; 03-21-2010 at 06:31 PM. Reason: clarity |
03-21-2010, 06:26 PM | #25 |
Here's a picture of it...
