03-18-2010, 11:33 PM | #1 |
'73-'80 Fiberglass hood, trying to make it work
For you guys and gals with a fiberglass hood on your '73-'80, what are you doing for hood springs? Can they just be heated with a torch to weaken them?
Also, I have the inside hood release, and the hood (I think it's a Harwood) does not have the provision for the safety release hook. The previous owner simply left it off. I was thinking of cutting the correct shaped hole and making some sort of striker plate for the safety hook to ride against. This would keep the release hook from chewing up the fiberglass. Has anyone else tried this? |
03-18-2010, 11:40 PM | #2 |
6.0 powered square
Re: '73-'80 Fiberglass hood, trying to make it work
on a 80 I worked on the left the springs off and used a hood prop rod
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
03-18-2010, 11:42 PM | #3 |
I could do that, but I like being able to just lift up the hood and have it stay there. It's more classy
03-19-2010, 12:32 AM | #4 |
03-19-2010, 01:23 AM | #5 |
That kind of like my idea, the shocks off of the hatch of a suv? Fiberglass is lighter and saw them use on the other forum on a dually and I think his hood was steel but should work. Depending on what build you may be working on you could go with hood pins instead of a latch. I have a friend that has some on a honda with a fiberglass hood and works fine.
