Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-19-2010, 12:59 AM   #1
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
New rubber Whats next?
Hello brothers & sisters.
I received my new 28x14.5 QTP today along with the long length kicked out pan-hard bar to clear aftermarket diff cover.
Marv has been such help with his advice on the wider tire and lower launch RPM to better my 60 & to make it more consistent. I have also read up on everyone's input on the 3" exhaust. I have the 1 3/4" hooker super comps with 3" collector. I'm currently running 2 1/2" w/ X-pipe and delta flows.
The new pan-hard bar is going to hit the exhaust so its time to run 3" since my 406 put up low lower 600hp.
My question is should I run another x-pipe system and what types of mufflers are out there to run besides flow-masters?
Thanks for your input in advance.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 03-20-2010, 07:11 PM   #2
team39763
Re: New rubber Whats next?
I hear Dynomax Ultra-Flo's are good race mufflers...not the bullet ones, but the oval ones. I'm gonna try the bullets on mine though.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 03-26-2010, 12:52 PM   #3
Shon
X or H-pipe if you are looking for every little bit and a straight thru muffler is your best bet.
Depending on how loud you want it at idle would really depend on what muffler you want.
The Magnaflows are quietest at idle and the Dynomax will be about the same sound level as the flowmasters.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 03-26-2010, 02:31 PM   #4
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Borla xr-1 mufflers are real good i love mine. i have a question 68 C-10 where did you get the long length kicked out pan-hard bar to clear aftermarket diff cover. my pan-hard bar is hitting my cover now. im wanting to run a aftermarket diff cover but cant.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 03-26-2010, 02:36 PM   #5
Shon
Have you looked into the low profile covers from TA Performance?
Old 03-26-2010, 03:03 PM   #6
limitedstreetoutlaw
no i havent thought bout that thanks
Brandon
Street Car Mafia
Old 03-26-2010, 03:05 PM   #7
Shon
If you like them, let me know, I am a dealer and if we want to do a GP or something like that I am here to help!!
Old 03-26-2010, 03:12 PM   #8
limitedstreetoutlaw
k thanks ill look at them
Brandon
Street Car Mafia
Old 03-26-2010, 03:15 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
I've heard a lot of good things about the Pypes mufflers, they offer a 3" X-pipe also. From what's on their website, their stuff sounds awesome. I would run an X if I were you, Flowtech has one with cutouts built into it, and Jeg's has one too, but the cutouts are in front of the 'X'. The Flowtech piece has the cutouts after it.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-27-2010, 01:57 AM   #10
68 C-10 KID
Mean Green
I bought the bar @ CCP. Looks to be a nice built piece.
AKA MEAN GREEN.
Old 03-27-2010, 02:20 AM   #11
68 C-10 KID
Mean Green
Thanks for the info on mufflers and X pipes. I didn't know that they make ones with cut outs now. Yes I'm going with a X-pipe system.
I would like to go out side of the box and run something different. Those Borla's sound tough guy.
Any one have info on spin tech?
I also need to figure out were to dump the exhaust out at. I currently runs straight out the back, I was thinking dump them down at the corners kinda like the GTO's
I ordered a new go fast goodie today. A system one oil filter.
AKA MEAN GREEN.
Old 03-27-2010, 06:34 AM   #12
ripdog28
ripdog28's Avatar
I have the Pypes Violators in 3in and LOVE it. Sound is just nasty. I would dump the exhaust before the rear axle or out before the rear tires.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 03-27-2010, 10:52 AM   #13
limitedstreetoutlaw
Thanks for info.
Brandon
Street Car Mafia
Old 03-27-2010, 04:48 PM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
Spintechs sound pretty cool, but for max power, I would run a straight through muffler like the Pypes or Dynomax Ultra Flows. They will flow the best since there's nothing in the muffler to slow the exhaust gas down. Borla's are really nice too if you have the money.
ECE also carries the track bar with the bend in it to clear the rear diff.
Adam
Old 03-27-2010, 07:03 PM   #15
fiddy9apache
fiddy9apache's Avatar
i prefure Dynatech oval case mufflers.
fiddy9apache is offline   Reply With Quote
Old 03-27-2010, 08:30 PM   #16
68 C-10 KID
Mean Green
Dang so many options to choose from. I see a lot of the dragsters and tube chassis cars running the Borla's. I will look into the Dynatech and the Pypes.
ripdog28 I might try to run the exhaust a little longer than that. I drive this thing all over town and to shows in the summer and the big track is 40 miles one way, so I will try to keep cab noise down a little.
AKA MEAN GREEN.
Old 03-28-2010, 04:02 PM   #17
Super73
Super73's Avatar
I was running a 3" X-pipe with Warlocks (uncorkable) for a while. Loved the system. I switched to a dual 3" electric cut outs hanging right off the header. Then to the muffler it necks down to a 2.5" turbo muffler to quiet it down..
The warlocks were nice for being able to uncork it at the track..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-28-2010, 06:43 PM   #18
bigsnookmaster
bigsnookmaster's Avatar
I run a 3" mandrel bent system with the x-pipe just behind the trans, with Dynomax Super Turbos.It dumps right behind the rearend. It has a real nice sound , not loud or cackly,and seems to make real power. Good luck
bigsnookmaster is offline   Reply With Quote
Old 04-23-2010, 12:01 AM   #19
68 C-10 KID
Mean Green
I bought the Borla xr-1's. Installed the new Panhard-bar and have the new 28x14.5's on.
I'm going to run the the truck with the new tires before I Do the 3" exhaust swap & the one piece drive line change out.
AKA MEAN GREEN.
Old 04-23-2010, 02:03 PM   #20
team39763
The new rubber looks good.
Old 04-23-2010, 10:38 PM   #21
MONTE
MONTE's Avatar
What style of tires are those?
MONTE is offline   Reply With Quote
Old 04-24-2010, 12:16 AM   #22
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Just an FYI here
i have dynomax bullets and they sound like crap
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 04-24-2010, 02:41 AM   #23
68 C-10 KID
Mean Green
Those are the Hoosier quick time pro's. They are a bias tire that is a tube type.
They are the widest short tire I could find besides the M/T drag radials.
AKA MEAN GREEN.
Old 04-25-2010, 10:07 PM   #24
69trk
69trk's Avatar
you will like those meats. same ones that i run. wish my rims were a 12" tho..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-25-2010, 11:29 PM   #25
68 C-10 KID
Mean Green
Ya I hope so. My plan is to be able to turn the 2 step up more so my 60's can get faster.
That's kinda my same thought. I think the 12" would help keep the tire a little more square. If I did my measurements right I need like a 7 1/4"-1/2" BS.
AKA MEAN GREEN.
